Stihl MS290 vs. 029?
   / Stihl MS290 vs. 029? #11
I have a Stihl 026 (1989), MS460 (2005), 018 (2007). They start a little lean, due to EPA regs, but not excessive. 4-5 full choke pulls, then they'll sputter, usually can't catch 'em in time to go off choke, then a couple more pulls w/o choke @ W.O.T. Not a huge deal to me.
The big M.S. 460 is my tree feller & trunk bucker, has compression release button for starting. Stihl has never failed me, they are built right, cost more but don't wear out.
Posters are right - don't use alcohol in gas at any amount in a 2 stroke engine - it washes 2 stroke oil off the cylinder walls, if engine is carbureted & the fuel comes past the crankcase. For fuel injected 2 strokes it does not matter nearly as much.
Also the semi or full synthetic 2 stroke oils are very good - engines smoke much less & lubricate better. Make sure you use air-cooled 2 stroke oil, the recipe is quite different than liquid cooled 2 stroke engine oil (marine).
   / Stihl MS290 vs. 029? #12
My one year old MS290 is going back the the dealer. Hardest starting saw I ever owned. It will be the last Stihl equipment I ever buy... same with my Stihl tiller...Doesn't start worth a darn. Sorry for the rant. Nothing pizzes me off like a non-starting two-stroke...
You have bad luck, or aren't doing something right.
   / Stihl MS290 vs. 029? #13
I have six stihl saws no problems at all with starting. Normally it takes at the most three pulls when cold.
   / Stihl MS290 vs. 029? #14
Stihl is renown for starting problems..
On the contrary, Stihl is known for reliable starting. It may take a few pulls but that may have more to do with their carb setup and how they flow fuel. I would rather pull 3 or 4 times and ALWAYS get a start 1 pull after first burp than have a saw that sometimes starts on one pull, other times 3 or 4 pulls, sometimes never.....
   / Stihl MS290 vs. 029? #15
All of my Stihl equipment-a 260 saw, a 320(?) blower,a 250 trimmer and a 85 trimmer-start the same.2-3 pulls with the choke on, then 2 pulls with the choke on. They have been the way since new-nothing less, nothing more. The 85 trimmer and the blower are 10-12 years old. 1 pull when they are warm.
Will
   / Stihl MS290 vs. 029? #16
Yeah they start almost as easily as an ECHO engine. My stihl ms660, ms361, 100rx and dads 026 all start in about 4 pulls after sitting as you describe. All my echos 770t , es 1000 and old string trimmer have generally started 1st or second pull.
I would not describe either brand as difficult to start.
To the O.P. After first pop on full choke you must go to half choke or you will flood it and have trouble getting it to fire
My buddies husky saws are definitely more cold blooded at least in his hands.
   / Stihl MS290 vs. 029? #17
I too have a hard to start 029. I use Stilh sythetic oil with 89. Maybe I should go to 91 octane? My weed whacker and my hedge trimmer will start on 2-3 pulls or less and my BR600 starts with one pull everytime. My usage is mostly seasonal and I dump the gas over winter and spray the cylinders. I can live with that.
   / Stihl MS290 vs. 029? #18
I thought (based on my dealers comments) the 290 is the new designator for the old 029. Mine is hard to start, but probably from old gas as I don't use it that often.
   / Stihl MS290 vs. 029? #19
When I go the dealer, I am going to ask them what I am doing wrong... I follow the manual exactly and still have tons of trouble starting the Stihl equipment. Maybe mine is not set up right from the factory? Using the "canned" gas, because all we can get here is ethanol. I love that Stihl when it runs, though!
My Echo equipment starts every time...two trimmers, a blower and saw...
   / Stihl MS290 vs. 029? #20
The 290 is the new saw? They havent made the 029 in over 10 years i guess, the have not made any 0?? saw in about that long that i know of?
I have an echo trimmer, it is way more cold natured but i think its due to a weak clutch and its down on power, i bought it second had from a freinds landscape buisness for $50 and it was one of the main ones they used for years!!
But to the SAW Pull your trigger and put it on CHOKE so that its at wide open on its own. Then pull the cord till you hear it fire. It probably will just burp once or twice, sometimes if really cold it will runn more?? Dont worry about catching it and pulling off the choke. It will die after it fires once, take you hand and move it to half choke, DO NOT TOUCH THE THROTTLE, then pull the cord and it should fire in 2-3 more pulls mabe only one if its a newer saw. Then grab the handle and you can pull the trigger to take it off wide open. Then just kind of warm it up before you go at it, the book says " to just hold throttle just enough so that the chain barely will move" this is proably for safty reasons, or you can just goose it like every one esle does and rev it lots.
I have used many stihl saws. I have owned a ms390 for 9 years and used an older 026 of my uncles, my friend just got a 290 all start the exact same. My saw has the most hours of them all on it. I have rebuilt the carb once as i thought it was the problem when i had a split fuel line, and have adjusted my carb out of factory settings and it still starts almost as good as new.
I work with loggers and have started various things that they have.. pole trimmer, numerous saws, some that are pretty beat, no trouble. Now most of those saws would be considered warm as they had run that day but they only run them for like 5-10 minutes every hour or so to trim trucks but there still in my opinion warm.
I think you may have gotten a lemon or just useing wrong procedure.
Like has been said if you pull the cord after it has fired that first time and you have not moved it to half choke it floods, and is a bear to start. You will have to then go to half choke but most likely you will have to drop start it with no choke and your hand holding the throttle or either let it set for a few mins. I have flooded mine not paying attention and it makes it way harder to start. But i have only done that once or twice in all these years.
500LB Livestock Galvanized Creep Feeder (A55218)
500LB Livestock...
UNUSED RAYTREE RMBD72S - 72" HYD DRUM MULCHER (A54757)
UNUSED RAYTREE...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2023 BOBCAT T66 R-SERIES SKID STEER (A52705)
2023 BOBCAT T66...
2017 Rogator RG1300B Dry Fertilizer Applicator (A55302)
2017 Rogator...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A55302)
John Deere 5090E...
