Can I use SUDT2 in B7800 HST?
   / Can I use SUDT2 in B7800 HST? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I picked up some SUDT2 for a HST change in my B7800 since I thought UDT was good, SUDT better and SUDT2 best. Go with the best I figure.
Also thought that SUDT was being phased out in favor of SUDT2. Can anyone confirm this so I can make sure I do the right thing?
Is SUDT still being made and will it be made side-by-side with SUDT2?
Is any of my thinking correct?
In the past I changed to JD trans fluid and there is more gear whine than there used to be. Time to change back.
   / Can I use SUDT2 in B7800 HST? #2
Go with the best it's not that much more, and it's better.
So is SUDT2 the best? I'm confused by the SUDT and SUDT2.
   / Can I use SUDT2 in B7800 HST? #4
Yes, SUDT2 replaced the SUDT. I read on the Kubota site that it is 75% synthetic. Fully compatible with UDT and SUDT.
   / Can I use SUDT2 in B7800 HST? #5
If your buying (have HST) and SUDT2 is available, buy SUDT2. If you have several gallons of SUDT on hand, like I do from past purchases, then use the SUDT without concern. I believe SUDT2 is replacing SUDT. UDT can be used in front axle or non HST tractors but I would use ONLY SUDT or SUDT2 for HST. The whine is loud enough in HSTs using SUDT/SUDT2 but I've heard here that it is worse with UDT and some have said it has made the trans (HST) more sluggish.
Every thing isn't about better or less better, some things are just made for certain applications/uses which can then make one better than the other no matter the cost.
Some greases are "better" (more expensive also) than other greases but in some applications the more expensive better grease will not do any "better" job than a cheap grease. So, is one "better" than the other if it doesn't perform any "better"?
Same principle appies to motor/engine oils.
2018 Deere 323E (A53317)
2018 Deere 323E...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
2020 Chevy Silverado (A56438)
2020 Chevy...
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
