Successful bandaid fixes for compression loss on small engines
   / Successful bandaid fixes for compression loss on small engines #11
Soundguy I am going to try the Sea Foam in the spark plug hole before I change the old oil in our 'new to us 2002 Polaris. Right now we are waiting for a new carb boot to reinstall the carb. Adding 1.5 oz per quart of motor oil is something that I do sometimes but letting it seep past the rings is a good idea however. Sea Foam in the engine oil under heat and pressure would have some 'flushing' effect and if it was softened already by a Sea Foam 'soak' that should be a nice plus. Running three gallons of gas with 2+ oz per gallon Sea Foam mix sure did get the relative clean oil black. What came out of the oil cooler was very thick and black but i doubt it was ever drained when the oil was changed.
BigMike50 thanks for sharing your experience. That was interesting results.
   / Successful bandaid fixes for compression loss on small engines #12
A lot of times the valves get gummed up and stick in the guides. Glad you got the compression back up.
   / Successful bandaid fixes for compression loss on small engines #13
I have seen valve seats pop out on a briggs. They usually come out far enough that the engine has a no compression. I hope your valve seat was not loose.
   / Successful bandaid fixes for compression loss on small engines #14
On those B & S engines we would set the seat back in place and stake it with a center punch around the edges. Lap the valve, sometimes cut seat and valve if needed. Was a good fix to keep it alive.
   / Successful bandaid fixes for compression loss on small engines #15
That is what I did. It held up for a little while.
   / Successful bandaid fixes for compression loss on small engines #16
Yeah, thats the time to Trade it or sell it. lol
   / Successful bandaid fixes for compression loss on small engines #17
I had 3 mowers that were the same model. 1 knocked, 1 smoked, and 1 had the valve seat out. I sold all 3 to one guy. I actually got more out of them then what I had in them.
I got a mint condition sears lt2000 off Craigslist for 50 bucks where the owner thought the engine blew up. My girlfriend needed a riding mower for her new house . I brought it home and it had no compression. Pulled the head and saw the exhaust valve seat popped out. I did what you guys did and peened it in there. Runs like new. Only been running for one season so far. If it happens again, I know that I just need to peen the intake valve.
   / Successful bandaid fixes for compression loss on small engines #19
i had valves on my 4000 ford prior model stick so bad they made artwork out of my pushrods. :)
   / Successful bandaid fixes for compression loss on small engines #20
Now that's a stuck valve!! I have seen that a lot on Forklift Engines too.
2012 Chevrolet Impala Sedan (A54815)
2012 Chevrolet...
9000 (A47477)
9000 (A47477)
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A57024)
2018 John Deere...
2021 CATERPILLAR 336GC EXCAVATOR (A52706)
2021 CATERPILLAR...
JCT 74" HYD VIBRATORY ROLLER (A52706)
JCT 74" HYD...
