New 860 owner
   / New 860 owner #11
Little paint is all.. Mine was rough looking too before the seller painted it..
   / New 860 owner #12
i've drug home worse. :)
i see it has a hyds valve hiding on it too. :)
   / New 860 owner #14
I see an " ugliest tractor" thread coming on.
   / New 860 owner #15
i see a caterpillar / butterfly transformation about to begin..
   / New 860 owner
Uh-huh, but I don't know anything about that block under the seat with the line coming out of it. Can y'all help? where would you start iffin it was you?
   / New 860 owner
You're all very encouraging but then again I, am compleeeeetly ignorant. The very first thing I did was to lose the key. Haven't installed a new key switch yet...next week. I intend to start spot blasting and priming the rear axle etc and replace the rear brakes. Then do a proper 12v conversion. Does this seem a viable path or do I have things sideways? How would you start?
   / New 860 owner #18
You should be able to just get a new set of keys.. pretty much all the same..
Paint comes after you make sure all the maintenance is done.. Like oils, cooling fluid, plugs, etc..
   / New 860 owner
What can you fine people tell me about this hydraulic block? hydraulic valve.JPG
   / New 860 owner #20
Thats most likely a single acting 'remote'. It allows you to use a hydraulic attachment off your PTO hydraulics..
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A53473)
Neckover GL24-2-7K...
2025 IR UNUSED Hydraulic Breaker (A53117)
2025 IR UNUSED...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A53473)
2000 Kenworth W900...
2019 Chevrolet Express (A50123)
2019 Chevrolet...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
Link-Belt 75X3 (A50123)
Link-Belt 75X3...
