Pond Outlet (Level) Control?
   / Pond Outlet (Level) Control? #1
CobyRupert
Super Member
Washington County, NY
JD 5075E
Anybody have any good links, pictures, ideas about products or designs that would let me adjust the height of a pond from about 6' to zero, and all heights in between? At max spring flows I need about a 12" pipe to handle the flow without relying on a spillway.
   / Pond Outlet (Level) Control? #2
A stop log structure is commonly used for managed wetlands to adjust water level. Basically a spillway with a concrete base and sides. Two metal channels on either side allow wooden boards to be slid into place and stacked on top of one another in the channel. To deepen, add another board or take one away to make it shallower. Excess water just flows over the top of the uppermost board.
Do you know if they are custom made /poured or does anybody make a precast?
   / Pond Outlet (Level) Control? #5
My pond has a 8" slide gate valve. It is under water now, can't get pictures.
Some good info here: Conventional Pond Piping System
Another way to do it: Anti Seep Collars and Dos Ir Water Control Overflow Valves Aquatic Biologists
inline_valve_EN.jpg Inline Water Level Control Structure
2021 KUBOTA SSV75 SKID STEER (A52707)
2021 KUBOTA SSV75...
2008 Featherlite Trailer with generator , VIN # 4FGE853218C108480 generator VIN- 4TCSU18516H185904 (A53422)
2008 Featherlite...
2005 International 4300 Telsta Telescopic Bucket Truck (A55973)
2005 International...
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
