What am I doing wrong with water pump?
   / What am I doing wrong with water pump? #31
From what it sounds like I agree with the others, it's most likely a carb issue. One possible cause could be the float is sticking because it's not assembled correctly or some other restriction where the fuel enters the carb. I think you're going to have to bite the bullet and take it apart or call the seller and see if they are willing to send you a replacement carb.
Past two days have been busy at work. Haven't had a chance to do anything with this. Will keep you posted.
FIXED!! Or at least I believe it is. Spoke with a SUPER helpful customer service guy on the phone this afternoon. Disabled the low oil sensor by disconnecting the lead wire. Worked fine right off the bat. Ill be using it a lot the summer so ill have plenty of chances to test it further. As always, Thanks for everyone's input!
   / What am I doing wrong with water pump? #34
Does the low oil switch have a sensitivity adjustment?
Is it attached properly, ie, level?:)
He didn't say. I believe so. Not really. I'll keep an eye on oil manually.
2021 Western Star 4700SF Tri Axle Dump (A47384)
2021 Western Star...
Kinze (Delgelman) MT 201 High Speed Disc (A52349)
Kinze (Delgelman)...
2013 FORD F150 LARIAT CREW CAB TRUCK (A51243)
2013 FORD F150...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
John Deere 2010 Loader Tractor (A50514)
John Deere 2010...
2015 Ford Expedition EL XLT SUV (A50324)
2015 Ford...
