What am I doing wrong with water pump?
   / What am I doing wrong with water pump? #31
From what it sounds like I agree with the others, it's most likely a carb issue. One possible cause could be the float is sticking because it's not assembled correctly or some other restriction where the fuel enters the carb. I think you're going to have to bite the bullet and take it apart or call the seller and see if they are willing to send you a replacement carb.
Past two days have been busy at work. Haven't had a chance to do anything with this. Will keep you posted.
FIXED!! Or at least I believe it is. Spoke with a SUPER helpful customer service guy on the phone this afternoon. Disabled the low oil sensor by disconnecting the lead wire. Worked fine right off the bat. Ill be using it a lot the summer so ill have plenty of chances to test it further. As always, Thanks for everyone's input!
   / What am I doing wrong with water pump? #34
Does the low oil switch have a sensitivity adjustment?
Is it attached properly, ie, level?:)
He didn't say. I believe so. Not really. I'll keep an eye on oil manually.
70pc. 12ft.x 3ft. Black Metal Roof Panels (A53424)
70pc. 12ft.x 3ft...
2021 JOHN DEERE 648LB SKIDDER (A51406)
2021 JOHN DEERE...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A54815)
2022 McConnel...
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
2018 Gatormade 20+5 Gooseneck Trailer (A55301)
2018 Gatormade...
2006 Mack CT713 Granite T/A Galbreath Roll-Off Truck (A55788)
2006 Mack CT713...
