Carl_NH
Elite Member
- Joined
- Apr 5, 2002
- Messages
- 3,961
- Location
- Coastal NH
- Tractor
- 01 Kubota B21TLB, 2010 Ferris 52" ZTR, Cub Cadet 1811, Gravely Super8
Its real easy - take the hood off - should slide right off the front hinges and unhook the headlight wire. Then you will have easy access to the cover(s) one if a single Cyl and 2 if a twin cylinder.
I have done both neighbors machines and adjusted valves as well in about an hour. I also just use blue silicone "rtv" sealant instead of buying gaskets - its available at auto parts stores.
For adjusting valves, (with valve cover off) remove sparkplug, turn over engine until piston is at the top (stick a screwdriver into plug hole and turn engine by hand until its at the top) then use a feeler gauge (again from auto parts store) to check the valve clearance. Should be 005-007" if in that range you are OK. If more than ..008-010" I would adjust. It takes several trys to get it right..
You can find tips on line about this too.
Carl
Carl
