New 860 owner
   / New 860 owner #11
Little paint is all.. Mine was rough looking too before the seller painted it..
   / New 860 owner #12
i've drug home worse. :)
i see it has a hyds valve hiding on it too. :)
   / New 860 owner #14
I see an " ugliest tractor" thread coming on.
   / New 860 owner #15
i see a caterpillar / butterfly transformation about to begin..
   / New 860 owner
Uh-huh, but I don't know anything about that block under the seat with the line coming out of it. Can y'all help? where would you start iffin it was you?
   / New 860 owner
You're all very encouraging but then again I, am compleeeeetly ignorant. The very first thing I did was to lose the key. Haven't installed a new key switch yet...next week. I intend to start spot blasting and priming the rear axle etc and replace the rear brakes. Then do a proper 12v conversion. Does this seem a viable path or do I have things sideways? How would you start?
   / New 860 owner #18
You should be able to just get a new set of keys.. pretty much all the same..
Paint comes after you make sure all the maintenance is done.. Like oils, cooling fluid, plugs, etc..
   / New 860 owner
What can you fine people tell me about this hydraulic block? hydraulic valve.JPG
   / New 860 owner #20
Thats most likely a single acting 'remote'. It allows you to use a hydraulic attachment off your PTO hydraulics..
2025 K2010 UNUSED Chicken Coop (A53117)
2025 K2010 UNUSED...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A53473)
Texas Post Driver...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
2012 Caterpillar 259B Compact Track Loader Skid Steer (A51691)
2012 Caterpillar...
