JD 450C will not start after normal operation and normal shutdown
   / JD 450C will not start after normal operation and normal shutdown #1
greenmojo
Gold Member
Badger Mountain, WA
John Deere 4300, John Deere 450C
Hello all!
This is the only place I could think of to bring an issue with my recently acquired 1980 John Deere 450C. I've only posted a few times, but read constantly. I appreciate any feedback and guidance, thanks in advance.
I'll detail the full picture here, possibly to help with diagnosing and not wasting anyones time.
I bought the 450C about 1 month ago or more and had it first delivered to Pape Machinery up here in the pacific northwest, they replaced a few hoses, a throttle cable, radiator cap, etc -- otherwise giving it a clean bill of health before delivering to my property. The dozer started and ran great, and I ran it for more than 20 hours or more without a single issue.
Symptoms:
Upon moving the dozer one evening, I went to start it up and the start button had absolutely no effect. The key turned, there was a little gauge movement, but the starter button when pressed made no sound, nothing. There was a little change on the battery gauge, but other than this nothing. In order to start the machine, I shorted the solenoid and it fired right up. Strangely, it actually worked about 4 or 5 times with the starter button after this, before once again the starter button appeared to no longer work.
This went like this for about a week, when in fact the starter failed completely. When I pulled the starter and took it down to Pape, they discovered that fuel had leaked into the starter and caused it to fail, which still puzzled them and me why the starter button was intermittently having issues. I was hoping a new starter / solenoid would fix the issue, and eagerly got the new starter / solenoid installed.
As soon as it was installed, I turned the key, hit the button and it fired up better than it ever had. I also found the fuel leak and tightened up that line. This starting / stopping continued for about 8 times yesterday afternoon following the repair, however I shut it down for a few minutes and when I jumped back on it, the start button issue had returned. A push of the button has absolutely no effect at all. Just a small fluctuation in the battery gauge, but other than that -- no sound, no solenoid click, no crank, nothing.
As for the common neutral safety wiggle that some 450 dozers have, this one doesn't have that -- we've never had to wiggle or adjust, we just put it in neutral and it would start right up. And just to be sure, I've tried to hold the start button and wiggle the heck out of gear lever, and nothing appears to happen.
I would appreciate any insight, guidance or experiences to help. I absolutely love moving dirt with this machine and would love to have it back in push button start operation again.
I'll attach a photo, of the machine.
Thank you,
   / JD 450C will not start after normal operation and normal shutdown #2
It could be a faulty push button or wiring.
Very nice looking old dozer, btw.
   / JD 450C will not start after normal operation and normal shutdown #3
I would start by checking for voltage at the solenoid to make sure you are getting power thru the switch, just verify that the switch is working. I would also suggest you check all the wiring from the batteries cables including the ground to the frame/block. Might be as simple as a loose connection to the starter switch as this could vibrate loose while running and would not be noticed until you tried to start it again.
   / JD 450C will not start after normal operation and normal shutdown #4
As I read this I was thinking bad ground or loose connection, jenkinsph beat me to it.
On the first go-around before shorting, we thought we had correctly diagnosed that there was voltage through the solenoid. However, just to be sure and start fresh, I will check this again and then report back. The new house is about 3 hours away from our current home, so I will be there on Monday or Tuesday.
Thanks for the insight, if anyone has any other ideas to check when I am there, I am open. Thank you,
~moses
   / JD 450C will not start after normal operation and normal shutdown #6
Unless the neutral start switch(parts key #16) has been circumvented(bypassed) I'll bet JD installed one for everyone's SAFETY. JD installed these kit's to aid in low voltage on the starter solenoid exciter wire.
RE42993 Starter Motor Kit ADD 93.09 USD
I don't know enough to follow your train of thought here.
Is this something I should look at installing or is this where my problem may be at?
I sit behind a keyboard all day, and am slowly learning (and loving) the mechanical side of things. Sorry for not being able follow you as quickly as I should.
~moses
   / JD 450C will not start after normal operation and normal shutdown #8
1st photo shows location of JD factory installed neutral start switch
2nd photo shows a kit that JD introduced for hard to start utility tractors(same engine as 450C) because of voltage loss between battery to ignition switch to neutral start switch to starter solenoid. Kit eliminates amperage drop from key switch to solenoid on starter solenoid excitement(energize) wire. That's the best diagnoses I can give you from the info you given me.
   / JD 450C will not start after normal operation and normal shutdown #9
Possibly a faulty key switch. Not powering start button every time.
TxJim are there any circuit breakers that could be intermittently failing?
Excellent, that makes complete sense. The neutral safety switch is installed and does work (when it started), as sometimes I would forget to make sure it was in neutral before starting and there would be no response.
I'll pull the panel off when I get over there and see what is there, I imagine from your photo that I'd be able to tell if that had been installed or not.
I'll also check the switches and start button. Thank you all so much, and again, if you have even the slightest ideas of anything else I should check, I am open.
~moses
   / JD 450C will not start after normal operation and normal shutdown #11
MY knowledge of JD ind equip is very limited as dealer I worked for was AG only. I can't think of a circuit breaker on start circuit on JD utility tractors but then I'm getting "Oldtimers disease"!!!!!!!
   / JD 450C will not start after normal operation and normal shutdown #12
Reason I mentioned CB is a logger with a JD log skidder had a no start issue. He bypassed something on the right side of the engine compartment that looked like a CB. Sold a few trees this spring.
   / JD 450C will not start after normal operation and normal shutdown #13
Were you ever able to get your JD 450C working again? I am having the same problem.
   / JD 450C will not start after normal operation and normal shutdown #14
AKERDoc
Give the OP a PM (personal message) to touch base with him. Click his user name and there you will see that feature. Has been awhile since being active.
Hope others will chime in here as well. Any more info you can add to your problem to liven up the interest on TBN? history, when last working well, etc.
Welcome to TBN
   / JD 450C will not start after normal operation and normal shutdown #15
Welcome to TBN
Have you checked/cleaned all battery cable connections? If ground cables are attached to sheet metal I suggest to relocate ground cables to engine block for more cranking capacity. Have you load tested batteries?
   / JD 450C will not start after normal operation and normal shutdown #16
AKERDoc
Welcome to TBN
Good Morning and greetings from Alaska (a nice and balmy 0 here on our mountain this morning).
As a retired ER Doc, I am not much of a mechanic. I live on the side of a mountain at about 1600 feet so we get a fair amount of snow and I have 3/4 mile of driveway to plow. I don't use it a great deal. A few times a winter, I run out of room to push the snow off the side of the road, and get to have fun on my 450C pushing the snow to widen the road so I can continue plowing. We also heat with wood, and I use the cat to pull trees out of the woods. I also use it 2-3 times a summer to grade the road to remove pot holes. I bought the cat back in 1982 when we were building our home. It really is fun to use.
In all these years, I never have had any problem starting it as long as I plug it in for a couple of hours to warm it up. I went to start it a couple of weeks ago and it wouldn't crank over at all. When I switched on the key, the gages would flicker, but nothing at all happened when I pressed the start button. I always put a charger on the battery when I plug in the cat to warm it up so I figured that the battery was fully charged, but just in case, I tried a different battery. That didn't help. Two days later, I gave it another try, and this time I wiggled the shift lever back and forth to make sure it was in neutral and then tried starting again. After pushing the start button a couple of times, it fired right up with no problems. I turned the cat off, and then had to wiggle the shift lever again a couple of times and it started right up again. This makes me think that the problem is either in the Starter Push Button or the Neurtral Safety Switch.
How difficult is it to replace the Neutral Safety Switch, and where it is located?
Thank you so much for any help and advice.
   / JD 450C will not start after normal operation and normal shutdown #17
Welcome to TBN
I cleaned the battery terminals and reconnected them. The negative cable is connected to the metal of the battery box which is located just to the right of the shift levers.
   / JD 450C will not start after normal operation and normal shutdown #18
NS switch is key 14. I've witnessed removing 1 or more shim washers(key 15) & reinstalling original switch has solved non start condition.
   / JD 450C will not start after normal operation and normal shutdown #19
Thank you for the information. Where is this located? Where does the shift lever connect with that chain of parts? How do you get to the Neutral Safety Switch?
   / JD 450C will not start after normal operation and normal shutdown #20
2018 JLG 742 TELESCOPIC FORKLIFT (A60429)
2018 JLG 742...
2017 FORD F-150 XL CREW CAB TRUCK (A59823)
2017 FORD F-150 XL...
1999 GMC C7500 S/A Dump Truck (A59230)
1999 GMC C7500 S/A...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
2019 CATERPILLAR 239D3 SKID STEER (A60429)
2019 CATERPILLAR...
John Deere 5105M (A53317)
John Deere 5105M...
