Bakhoe Mount Failure on Ford 2120
   / Bakhoe Mount Failure on Ford 2120
Is that a clean new break or did it break prior to you buying it? I can't tell from the pictures. Does the weld on the other side look the same? That may tell you if it was factory. My guess is the same as the others, a cheesy weld job by the previous owner and paint to hide it.
Sorry, I just took the quick pictures, Attached are the original versions.
   / Bakhoe Mount Failure on Ford 2120 #12
I can see porosity through the paint! Yeah... not the best welds;)
   / Bakhoe Mount Failure on Ford 2120 #13
Agree with others who say those welds look bad.
When you get a welder to look at it, have them inspect it for any other weld "repairs".
Hope those were the only ones.
Good luck and let us know how it turns out.
   / Bakhoe Mount Failure on Ford 2120 #16
Second opinion, Doctor!
Just a follow-up, I had it welded this past weekend, and it was pointed out to me that it is missing a 3rd link, which may have prevented the failure. The welder is going to source a 3rd link for me as well.
I am looking to buy an ignition key, owners and services manuals (CD/DVDs would be ok) and some Ford New Holland blue spray paint. Anyone have any good 'net sources?
I am also looking for a york rake with wheels, but local to zip code 03448 or 01095 would be best.
Thanks!
2016 KENWORTH T680 TANDEM AXLE MID ROOF SLEEPER TRUCK (A53426)
2016 KENWORTH T680...
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
UNUSED HURRICANE 20' X 20' ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
