Bakhoe Mount Failure on Ford 2120
   / Bakhoe Mount Failure on Ford 2120
Is that a clean new break or did it break prior to you buying it? I can't tell from the pictures. Does the weld on the other side look the same? That may tell you if it was factory. My guess is the same as the others, a cheesy weld job by the previous owner and paint to hide it.
Sorry, I just took the quick pictures, Attached are the original versions.
   / Bakhoe Mount Failure on Ford 2120 #12
I can see porosity through the paint! Yeah... not the best welds;)
   / Bakhoe Mount Failure on Ford 2120 #13
Agree with others who say those welds look bad.
When you get a welder to look at it, have them inspect it for any other weld "repairs".
Hope those were the only ones.
Good luck and let us know how it turns out.
   / Bakhoe Mount Failure on Ford 2120 #16
Second opinion, Doctor!
Just a follow-up, I had it welded this past weekend, and it was pointed out to me that it is missing a 3rd link, which may have prevented the failure. The welder is going to source a 3rd link for me as well.
I am looking to buy an ignition key, owners and services manuals (CD/DVDs would be ok) and some Ford New Holland blue spray paint. Anyone have any good 'net sources?
I am also looking for a york rake with wheels, but local to zip code 03448 or 01095 would be best.
Thanks!
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
UNUSED JCT HYD HD BACKHOE ARM (A51248)
UNUSED JCT HYD HD...
UNUSED WOLVERINE BC-13-72W-72" HYD BRUSH CUTTER (A51248)
UNUSED WOLVERINE...
2017 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2017 KENWORTH T680...
UNUSED WOLVERINE QUICK ATTACH MOUNTING PLATE (A51248)
UNUSED WOLVERINE...
UNUSED JCT 72" HD BRUSH CUTTER (A51248)
UNUSED JCT 72" HD...
