Buying Advice Kubota ZG332 60" mower commercial
   / Kubota ZG332 60" mower commercial #1
hope
Woodville, AL
2013 Kubota ZG327 60" commercial
Any good or not good advise on the Kubota ZG332 60" mower commercial? I'm very close to buying, and they are VERY PRICEY!! Thanks
   / Kubota ZG332 60" mower commercial #3
I run a ZD323 on my property, no regrets. They only look pricey, factor in they will last forever (you know what I mean) they come out less expensive over time. Question for you, why a gasser over a diesel?
I believe the diesel will have a higher cost maintenance. Is the diesel better in quality or performance? Why not a gasser over a diesel?
   / Kubota ZG332 60" mower commercial #5
The diesel will give you better fuel economy, more power and is more durable. There's a reason they put diesel engines in heavy duty equipment. Yes the maintenance costs are a little higher but a diesel could literally last your lifetime assuming you are one for regular maintenance.
   / Kubota ZG332 60" mower commercial #6
In some diesel applications maintenance can be more expensive because of the larger volume of engine oil, fuel filters, and water separators that need replacement more often. On a ZD, the engine oil is just less than for quarts if I remember correctly, I change the oil ever 100 hours of operation and the fuel filter yearly. I do not have a water separator. Perhaps in automotive applications the diesel is more expensive to maintain but not in this case, I think would it would be less, no spark plugs or troublesome carburetor.
Diesel fuel has more energy than gasoline thus diesel engines use considerably less fuel than gasoline engines to do the same amount of work. They also produce their torque at a lower RPM reducing the amount of fuel used. I saw a significant savings between diesel and gas mowers, about 40% less fuel used to cut the same area.
   / Kubota ZG332 60" mower commercial #7
I would imagine the diesel will be less maintenance until they start putting all the emissions crap and high pressure fuel pumps on them. At that point, it will probably be a wash honestly.
Right now while we still have good ol fashion real diesels you should be good to go and they will use a lot less fuel too.
   / Kubota ZG332 60" mower commercial #8
The Kubota chassis lawn mowers have been great as far as longevity. We have seen them well past the life of two gas engines and still going strong.
   / Kubota ZG332 60" mower commercial #9
Buy it and don,t look back.I had a 2008 ZTR Kubota 326 pro model (diesel)60 inch deck.They are built like tanks.coobie
   / Kubota ZG332 60" mower commercial #10
I always had gas engine equipment, especially lawn mowers. About 10 years ago I bought my first diesel tractor and haven't looked back.
This year I traded my gas mower for a Kubota BX2360 and enjoy not having to worry about ethanol problems that go with storing fuel. The fuel efficiency is also better than my gas mower. Plenty of power too for a 60" deck.
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A51222)
2004 HYUNDAI...
John Deere 825i Gator (A50514)
John Deere 825i...
2022 CATERPILLAR D4 LGP CRAWLER DOZER (A51242)
2022 CATERPILLAR...
FORD 7600 TRACTOR (A51243)
FORD 7600 TRACTOR...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
1985 International X Con Semi (A50514)
1985 International...
