Deere 2305 Cylinder Head Cracked - Where can I find another one?
   / Deere 2305 Cylinder Head Cracked - Where can I find another one? #11
   / Deere 2305 Cylinder Head Cracked - Where can I find another one? #12
Just my two cents worth. If the engine got hot enough to crack the head, damage occurred else where's also. At a minimum I would drop the oil pan and check the bearings. I would also replace the rings. Rings do not like being exposed to extreme heat.
   / Deere 2305 Cylinder Head Cracked - Where can I find another one? #13
That is what I was thinking.
   / Deere 2305 Cylinder Head Cracked - Where can I find another one? #14
If you're still considering replacement head, may want to give these folks a call. Industrial - Irrigation - Industrial-Irrigation Services - have always been good to work with in my experience (OEM). Don't know where you are located in CO but they are south-central NE. Did a check on their website and it looks like they carry the 3TNV76 also, but it's labeled -CSA and as an industrial diesel - may be some differences there. If they don't have access to the parts they would probably be able to give an alternate supplier. They also have a Yanmar spec sheet on the V76-CSA engine in their Yanmar section. Good luck with the repair.
I am considering buying a new engine and parting my out. Is there much demand for 3TNV76 parts with 200 hours on it?
   / Deere 2305 Cylinder Head Cracked - Where can I find another one? #17
If you go with the new engine, is it a newer upgraded version?
   / Deere 2305 Cylinder Head Cracked - Where can I find another one? #18
Is it new or rebuilt? IF it is rebuilt they will probably want your old one back unless you pay a core charge.
   / Deere 2305 Cylinder Head Cracked - Where can I find another one? #19
As previously stated. It's worth unbolting the cylinder head and using a straight edge after checking for cracks.
Repair cost should not matter as the $$$ should be coming out of the boy's pocket.
Well...here it the latest. The head is warped .007 in the middle and has a small crack. I am going to talk with someone about it tomorrow, but I think it is toast.
I pulled the motor and removed the pan. There was a small nugget of metal that was in the pan. No other metal was present that I could see. I pulled the main caps and looked at the underside bearings and rods for all three cylinders. They looked great. The nugget could have been there from the initial startup...who knows. I verified that the block and cylinders are not warped. The only other thing that I am a bit concerned about is there is a hairline type groove in the #2 cylinder wall. You can feel it with your nail. I am thinking about removing the piston and verify the rings are ok. If the rings are ok, I will probably buy a new head and put it back together.
I will do a leak down test on it when I put it back together - prior to putting it in the tractor to verify rings are good. With only 200 hours on the motor my compression should be fine.
Stay tuned!
2023 Globe Booster Flipaxle (A51572)
2023 Globe Booster...
378812 (A51573)
378812 (A51573)
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
Caterpillar 430D 4x4 Extendahoe Backhoe Loader (A51691)
Caterpillar 430D...
