It amazes me the unsafe way people haul stuff....
/ It amazes me the unsafe way people haul stuff.... #1
denverdave66
Missouri
2012 John Deere 1016, FEL, 60"MMM
I never really paid much attention to how people hauled tractors and equipment on trailers until I started hauling mine. I am a rookie only have hauled my John Deere 1026 on my trailer a couple of times but I wanted to do it right and be safe. I don't care for ratchet straps so I went out and bought 3/8" frade 70 chain and used my chain binders to take up the slack. I saw a guy the other day hauled a skid steer and only had 1 chain and it was a small chain going over the rear and no chain binders at all, it was so loose if he made a sharp turn I guarantee it would have turned over. I just can't believe the way people throw there equipment on trailers and not even worried about if they are not tied down properly. I prolly go a little overkill since my 1026 prolly weights less than 2000 pounds but I no its not going anywhere. Check out my pics and if you see I am doing it wrong let me know. I want my equipment to be safe. If and when I haul the loader or brush hog I will throw a chain over them too or use a ratchet strap.
/ It amazes me the unsafe way people haul stuff.... #2
One chain at each end would be adequate, but like you said this way you know you are fine.
/ It amazes me the unsafe way people haul stuff.... #3
You need 7-10% of load on trailer tongue.
I thought you suppose to center the tractor over the axles. So you saying I need to back up another foot or two? Like I said I am a rookie and want to do it the correct way, not like the yahoo's I have living in my town that throw a small chain over the tractor and not even put a chain binder on it.
/ It amazes me the unsafe way people haul stuff.... #5
On the tractor front end chains, I would take the chain under that front bar, up behind, then hook it on the top of the bar. I like gravity to help keep hooks on.
Bruce
/ It amazes me the unsafe way people haul stuff.... #6
Weigh balance looks great in photo
/ It amazes me the unsafe way people haul stuff.... #7
Not to nit-pick, but you asked.
If your hooks face down they won't come off if the chain should go slack, for whatever reason. If you tie, tape, wire, however you can, the binder handles, they won't release on their own.
Again I am nit-picking. I wish everyone would tie machines down like you do.
Back in the early 70's several times I noticed a road construction crew transporting their dump truck and backhoe without using a trailer. They would lower the loader bucket into the back of the dump untill the loaders front wheels came off the ground. That was it. Off they went with the TLB being towed behind the dump.
Best, Bill
/ It amazes me the unsafe way people haul stuff.... #8
Normally the C.G. of an empty tractor is about where the steering wheel is. So to me, that looks like it's too far forward on the trailer.
The jack is down in these pics, so we can't really judge the balance.
/ It amazes me the unsafe way people haul stuff.... #9
You guys would love to see my pics, I haul with a ton and a half rack truck but I drive the tractor ahead so I have a lot of tongue weight. when I haul my 790 almost the whole tractor is ahead of the axels. Makes the trailer haul like a dream and the truck can handle it. I say the more tongue weight the better, that looks like a good position if the truck can handle the weight on the hitch. Chaining looks better than most, better than mine a lot of times. I almost always use 4 chains but I hook 2 then drive the tractor to pull them tight and then 2 more with binders, that's on a deck over equipment trailer.
/ It amazes me the unsafe way people haul stuff.... #10
It looks like it is tied down very well.
I think it could go farther forward than what you have it but I am looking from a computer. I just usually watch how much the tow vehicle squats and see how the trailer pulls.
If you want to get technical do this, scroll to the bathroom scale method
Determining Trailer Tongue Weight | etrailer.com
/ It amazes me the unsafe way people haul stuff.... #11
Definitely needed! That's what the little holes in the end of the binder handles are for. That's required by Federal regulations for commercial haulers. An alternative is to wrap excess chain around the binder handle.
You have a good start in doing things the right way, just a few small issues as noted.
The federal regulations do not apply to us legally since we are not commercial haulers. However, the regs do provide good information on how to do it right:
http://www.fmcsa.dot.gov/cargosecurement.pdf
And yes, you need 10-15% of the weight on the tongue, otherwise the truck can become unstable. That's more important when hauling heavier loads with a lighter vehicle.
/ It amazes me the unsafe way people haul stuff.... #12
Also to save a little time you do not nee binders on the front....just drive up hook up your front chains back up till there tight and set the parking break then shut off the tractor and put your rear chain and binder on. And up here we need 4 chains for tractors on a trailer an in the X
/ It amazes me the unsafe way people haul stuff.... #13
Looks pretty good to me on the weight distribution. You dont want TOO much load forward of the axles. That puts most of the load only on the front axle, and not much on the rear. While it may ride better for the truck, the axles dont like it as much. When I load mine, I pull on and when I see the truck squat a little more than when empty, its good.
As others noted, same about the chains. Always try to go under and hook the chain so the hook cant fall off with gravity. Kinda the way you tied to the trailer. BUT...in your last pic, the hook on the left (front of trailer), the hook should be at the back side of the pocket. IF that chain were to slip around to the back side, your chain would be loose.
/ It amazes me the unsafe way people haul stuff.... #14
Also to save a little time you do not need binders on the front..
While true, it works better with adjustments on all chains. A little bit of bouncing down the road and any one of the four could have slack. If you don't have adjustments on the chains, you have to start up the tractor and back it up to snug it up. FMCSA requires adjustments on all chains for commercial haulers.
Which brings up another point: it's a good idea to stop after a few miles and check all the tie downs.
/ It amazes me the unsafe way people haul stuff.... #15
Bruce
I was gonna say the same thing. What you did was a good start. You just need to tweak a few more things to make it even better. first follow bcp advice. Chains go under-inside then up then over to hook on bottom. This way if chain becomes loose or unshackled , the chain will NOT fly around in the wind/air. It stays inside the tractor frame. Second, the chains should be wrapped around the lever to binder, not in between. This way if binder snaps open from a bump, the chain acts as a stop to prevent flying open and off. weight of chain helps too. Next, in the back, you did good- it really is tough to chain down on a sub compact tractor- due to narrow frames. In the rear its more important to have tiedowns in an X (cross) fashion. You have yours in a V shape. In the front its best in X fashion, but a v can be done with no problem, but the rear really should be in an X.
Keep in mind - the rules taught by army guys, trucking industry, etc - but you are just a home owner moving a lightweight equipment and most likely will not be issued a citation but its something to keep in mind in safety aspect.
/ It amazes me the unsafe way people haul stuff.... #16
If the hood hinges forward, be sure that it is latched securely before hauling, particularly if you are hauling it loaded backwards. The slipstream can catch the hood and slap it open very forcefully in an instant. I lost the whole hood assembly off a lawn tractor that way a few years ago (but it didn't have a latch...so [after repairs!] I just avoided loading it facing backwards).
BOB
/ It amazes me the unsafe way people haul stuff.... #17
In Michigan, the State Police motor carrier enforcement folks don't care if your moving a private load or are for hire. if they observe a load not secured to federal specifications your gonna get pinched. They are not bashful about it either.........
/ It amazes me the unsafe way people haul stuff.... #18
Wish more places were like that!
/ It amazes me the unsafe way people haul stuff.... #19
Numerous folks say it looks good the way it is. You need to go by what is actually the case and measure tongue weight. 10-15% is what I meant to say is required, and it is for proper weight distribution for the tow vehicle as well as the trailer. Too little weight and the trailer may act up as far as your being able to control it with your vehicle. Too much weight on the tongue and your tow vehicle can be hard to control, especially if you have to panic stop for one of the yahoos in your neighborhood.:confused3:
Follow what is suggested by etrailer.com and their methods to weigh your trailer tongue weight. once you know where to place the tractor you can repeat the positioning in future.
Show pics of final setup, thx.
Thanks for all the helpful hints, like I said this was my 1st time tieing something down on a trailer. I ordered my Doolittle special cause it is hard to find brakes on a 16' landscaping trailer, much less brakes on both axles. That's why I ordered it special wanted brakes on both axles. My truck has a brake controller in it, but is old and don't think it is working properly I have adjusted it all the way and don't think it is engaging the brakes. What's a good brake controller? My truck has a lot of power when not pulling a trailer it don't have the stock motor in it rather a 327 bored 30 over with a 4 barrel holley and headers on it, but when pulling this trailer with the gate up it seems like it is all it can pull, I can't pull out in front of someone but once I get up to 65 mph it pulls fine. Any ideas on that?
UNUSED IRANCH MINI EXCAVATOR WOOD GRAPPLE (A60432)
UNUSED IRANCH MINI...
Freightliner Columbia (A61306)
Freightliner...
2014 VOLVO A40G WATER TRUCK (A60429)
2014 VOLVO A40G...
2022 Horizon Trailer (A55973)
2022 Horizon...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2014 Nissan Juke SUV (A59231)
2014 Nissan Juke...
