5 hours on new Gator and problems already...
/ 5 hours on new Gator and problems already... #1
merlintractor
Colorado Front Range
MF 1260
Just had my new JD 825i delivered yesterday :) However, with less than 5 hours on the clock it now keeps popping out of high gear when I start to accelerate after initially putting it into gear :( Low gear seems to be Ok. Any ideas on what I could try before I drag this thing back to the dealer 50 miles away?
/ 5 hours on new Gator and problems already... #2
I've read about the problem before but never experienced it....it has been fixed by adjusting linkage in the past. The only crappy part is I don't know how the linkage is adjusted.
/ 5 hours on new Gator and problems already... #3
Does the dealer offer field service? I would assume they are supposed to do a rudimentary shake down drive before delivery. Then again maybe it is like a motorcycle that does a 150 mph. Hopefully no shake down on the scooter at 150 mph. They may not have a qualified mechanic to drive your Gator in top gear. ;-)
Seems to stay in high if I first go down to low then back to high; I can feel the detent a little better that way. But I don't think I should have to do that.
I'll have to check on the field service when I call the dealership in the morning...didn't see that mentioned in the warranty info.
/ 5 hours on new Gator and problems already... #6
The gator shows up at the dealership as a pile of parts in a crate. Somebody just slapped it together instead of assembling it.
/ 5 hours on new Gator and problems already... #7
You shouldn't have to.....the linkage needs to be adjusted and you'll be good to go. The service department may be able to walk you through doing it over the phone if you don't want to make the trip if they don't include on site service.
/ 5 hours on new Gator and problems already... #8
More likely it comes mostly assembled in the crate and the dealer puts on wheels/ tires and adds oil.
Its probably something simple like the shifter linkage needs adjusted.
/ 5 hours on new Gator and problems already... #9
I agree!! But may even have tires on it, just like atv's. they do a quick PDI, then send it off.
/ 5 hours on new Gator and problems already... #10
The dealer SHOULD either repair it in the field or if THEY can/prefer to walk you through it over the phone then they should refund the pdi fee. They didn't do the pdi properly, its not factory warranty but dealer labour warranty. They insist on charging the pdi fee but do very little for it.
Rant over.
Hope it all works out for you as I'm sure it will.
I feel better now.
Good luck!!
/ 5 hours on new Gator and problems already... #13
Just tell the dealer the DTAC and let them fix it..
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
2013 REITNOUER 48FT FLATBED TRAILER (A59905)
2013 REITNOUER...
2020 BOBCAT MT55 STAND-ON SKID STEER (A60429)
2020 BOBCAT MT55...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
