Ford 4610 - Oil and Fuel Do Not Mix!
   / Ford 4610 - Oil and Fuel Do Not Mix! #1
wjb-49
Lawsonville, North Carolina
LS MT573-CPS, Ford 4610
Well, I thought I finally had my 4610 in good running condition ( prior history: Burned Valve, Piston Issue), but a new problem developed this week. I was mowing with a rotary cutter and thought I had run out of fuel - the fuel gauge is not very reliable and I should have fueled up before beginning mowing. I had approximately three gallons of fuel remaining in a five gallon container and poured that in the tractor, which was on a slight incline. I tried to start the tractor and it would not run. The next day a friend and I tried to start it after bleeding the fuel filters and injector pump and it almost started, but would not. A couple of days later I tried, with the help of a guy who has worked on this tractor several times, to start it and it ran briefly and then stopped. He suggested that we put more fuel in the tractor because it was on an incline and may not be getting enough fuel. After pouring another five gallons in we managed to get it to run, but it was not running very smoothly and had a terrible "skip." I drove it about 500 feet and we shut it down. We then noticed that a mixture of fuel and oil was running out around the oil dip stick - not good! My friend said the tractor had either been vandalized (it ran out of fuel near a remote wooded area) or a seal in the injector pump was leaking. In order to drive the tractor to my equipment shed we drained the contaminated oil and replaced the oil filter and put in new oil. It sounded okay driving to the equipment shed. We decided to drive the tractor later and closely monitor the oil level. That was four days ago. This morning I checked the tractor and found that fuel\oil was overflowing around the oil dip stick again with the tractor sitting in the shed. Could this be a seal in the injector pump or something more serious? Remember, we rebuilt the motor last year and it was running fine.
Thanks,
-Barry
   / Ford 4610 - Oil and Fuel Do Not Mix! #2
umbrella seal could have gone...
   / Ford 4610 - Oil and Fuel Do Not Mix! #3
does that have a simms pump on it? (inline? )
   / Ford 4610 - Oil and Fuel Do Not Mix! #5
um.. never mind. you need to take it to a dealer. :)
   / Ford 4610 - Oil and Fuel Do Not Mix! #6
We have a bulldozer that has had this problem several times, it's the injector pump seal. My dad just replaced the pump last year and its leaking already. Same thing as you, oil is full of diesel. That part should be relatively cheap, ours for the dozer is only $35.00 and is real easy to fix.
Mike, That's what the guy who rebuilt the motor said it probably is. I did not discuss it with him and I thought replacing the seal would involve going into the injector pump and be a big (many $$$) job. I feel much better about this now that you let me know it's relatively inexpensive. Any thoughts about why this seal fails? Could it have been caused by my allowing the tractor to run out of fuel?
Thanks much!:)
   / Ford 4610 - Oil and Fuel Do Not Mix! #8
I'm not sure you even ran out of fuel, the diesel in the oil might have been the problem. On our dozer my it started to over heat big time so my dad thought he blew a hose or got a hole in the radiator, so we tore a bunch of the front end off (not the easiest job on a dozer) and couldn't find anything leaking. Well he pulled the dipstick and waahlaahh full to the top with diesel. So that's what made the motor get hot.
My guess as to why these things fail? I suppose I have a few theories, maybe the new fuels and older parts just don't mix. Or most likely, things made now a days are just China made junk compared to alot of the olden day America products. But maybe your mechanic has the real answer?
Don't get too excited just yet though about being a cheap fix, it prob is but until its confirmed it could always be a major fix. Our mechanic tested ours by taking off one of the lines (while the dozer was running) and then put his finger over the line. He said if the machine turns off then its this seal. Anyways I'm hoping for the cheapest option for you but you just never know. Keep us posted on the outcome.:thumbsup:
Our dozer is a John Deere so your New Holland/Ford might be quite different but lets stay positive.
. . . Our mechanic tested ours by taking off one of the lines (while the dozer was running) and then put his finger over the line. He said if the machine turns off then its this seal. Anyways I'm hoping for the cheapest option for you but you just never know. Keep us posted on the outcome.:thumbsup:
Thanks for the tip on how to test for a seal leak. Our mechanic may know this, but it never hurts to have a little knowledge for backup.:D I'm hoping he will have time to look at my tractor tomorrow, but tomorrow is his first day back in his shop following a long holiday weekend and that may put me at the back of the line! Will let you know what we find. Thanks.
Problem Solved!
We discovered we had two problems when we got into the injector pump - neither was very serious. As diagnosed by MikeDspain, the seal was bad. :thumbsup: When we removed the injector pump we also found that the shaft connecting the pump to the motor had come loose and the bolt that held the shaft had fallen into the pan below the shaft - would have been a serious situation had the bolt worked into the motor. After replacing the seal and correctly re-installing the shaft, it runs just fine!:D
Thanks for everyone's help!
   / Ford 4610 - Oil and Fuel Do Not Mix! #11
glad to hear it worked out for ya!
   / Ford 4610 - Oil and Fuel Do Not Mix! #13
Shoot man I was just trying to think positive for you, I don't know much about injector pumps. On my dads dozer the mechanic fixed the cheap part, changed the oil and thought it was all fixed. 2 hours later the oil was full of diesel again and my ol' man wasn't too happy. He just had the injector pump rebuilt last year and it has less than 10 hours on it. We shall see what happens now, if he has to pay the entire rebuild again or if it has any kind of warranty. So he's already out $250 plus the first pump $800ish, now it's a pump again and another oil change. It's amazing how a diesel motor can eat you alive if it needs repaired.
Glad you got yours fixed for the cheap though, that's always good news!:thumbsup:
Mike, Sorry to hear your dad is still having trouble with his dozer, hope the shop that rebuilt the injector pump will help him some with this repair. I know all to well how one can be cruising along just fine with a diesel and in a flash something goes wrong that takes a big bite out of the budget. Approximately 12 years ago our family business was running seven road tractors; I dreaded those middle of the night calls from a driver who had a truck broken down on the roadside.
Hope your dad's problem is minor!
-Barry
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A60429)
2019 CATERPILLAR...
1999 Toro Reelmaster 5400-D 100in Fairway Reel Mower (A59228)
1999 Toro...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
Blue Diamond 103709 (A53317)
Blue Diamond...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
