ford 8n starting probloms
   / ford 8n starting probloms
I have side mount distributor I am going to some voltage test today cables are new
   / ford 8n starting probloms #12
Then you have no resistor.
And what size are the cables?? Voltage drop is a much bigger concern on 6v than it is on 12v
It is side mount I just checked the voltage on battery and there is 6.28 volts and I is a 6 volt system
   / ford 8n starting probloms #15
Now clamp/hold the meter on the battery, and hit the starter and see what the voltage drops to?
   / ford 8n starting probloms #16
ditto.
also put a volt meter from bat hot to starter hot andf measure vdrop.
on a 6v system.. you don't want to see more than 1.5 normally.. and 2 max. that means you should be leaving 4.5v to the coil and a minimum of 4.. etc. less than that on the round coil systems and you will get weak spark.
the front mount have a more rudimentary coil.. and it can operate with coil voltages ( at the coil ) of 2.5-3v with 2.5 being poor spark.. etc..
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2016 FREIGHTLINER...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2013 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2013 Chevrolet...
1982 S&S FLATBED (A52472)
1982 S&S FLATBED...
New Holland 479 Haybine (A50774)
New Holland 479...
