ford 8n starting probloms
   / ford 8n starting probloms
I have side mount distributor I am going to some voltage test today cables are new
   / ford 8n starting probloms #12
Then you have no resistor.
And what size are the cables?? Voltage drop is a much bigger concern on 6v than it is on 12v
It is side mount I just checked the voltage on battery and there is 6.28 volts and I is a 6 volt system
   / ford 8n starting probloms #15
Now clamp/hold the meter on the battery, and hit the starter and see what the voltage drops to?
   / ford 8n starting probloms #16
ditto.
also put a volt meter from bat hot to starter hot andf measure vdrop.
on a 6v system.. you don't want to see more than 1.5 normally.. and 2 max. that means you should be leaving 4.5v to the coil and a minimum of 4.. etc. less than that on the round coil systems and you will get weak spark.
the front mount have a more rudimentary coil.. and it can operate with coil voltages ( at the coil ) of 2.5-3v with 2.5 being poor spark.. etc..
John Deere 7130 (A50120)
John Deere 7130...
2007 Ford F-150 Crew Cab Pickup Truck (A50323)
2007 Ford F-150...
KUBOTA M7-132 (A53084)
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
PENDING SELLER CONFIRMATIONS (A52576)
PENDING SELLER...
