Hydrostatic transmission for hilly land?
   / Hydrostatic transmission for hilly land? #1
Rob Bone
Rosemont, Qld. Aust.
Fiat 45-66 - 4WD
We have 17 acres of sloping to hilly land, and currently have Fiat 45-66... 4WD tractor (45hp) Have been considering upgrading, and wonder if hydrostatic transmission is any good on hilly land, and also what repair & maintenance problems arise.
Hoping I can get info on the pros. & cons. of hydrostatic trans.
Thank you
Rob
   / Hydrostatic transmission for hilly land? #2
I have a 4520 e-hydro. I dont have a lot of hills. I can say when pulling heavy loads - I have to go down to low range.
I would ask the dealer for a demo. See how it does.
D.
   / Hydrostatic transmission for hilly land? #3
D.
I agree, ask for a demo if a HST trans, and a powershuttle. Will be the best way to find out first hand.
Thanks Darin. So many tractors seem to have the hydrostatic trans. so at this point it's a general enquiry if that trans. is any good on hills. When I say upgrade, I mean to a later model with lower hours, but not a new tractor, and most likely will be from a private buyer, so demo probably not possible.
Thanks,
Rob
   / Hydrostatic transmission for hilly land? #5
:welcome: I do not have many hills around and the ones I do have are not a problem for my 5010 HST tractor. So far have had no repair problems with the HST. I have changed the HST filters and fluid once and I am at 355 hours on the clock. The next HST filter and fluid change is at I think 500 hours but I would have to check to be sure. I have had 2 other tractors both gear models and for me the HST is by far the easiest to operate for what I use the tractor for and wish I had purchased one sooner.:thumbsup: :2cents: Good luck.
   / Hydrostatic transmission for hilly land? #6
I have a L4400, 46 Horsepower, Kubota HST. I also use it on a lot of hilly terrain including slopes up to about 32 degrees. The great about the hydrostatic trans is I rarely use the brakes even on the steepest hills. I have used standard shift trans for years but I see the HST as a safety upgrade as I can change directions on the hills and never pass through neutral or risk missing the gear while shifting. As far as maintenance I have only had to service the HST with fresh filters and fluid at 400 hours.
   / Hydrostatic transmission for hilly land? #7
Our primary hill tractors not including three SCUTs are a Kubota L5740 HSTC and M8540 HDC, both work quite well, never had any mechanical issues with either or prior L5030 HSTC.
   / Hydrostatic transmission for hilly land? #8
I have had three JD with HST: 2210, 4720 and 4520. Never any transmission issues.
D.
   / Hydrostatic transmission for hilly land? #9
I have a Kubota L4610 with HST. I have pretty hilly terrain, not crazy steep but hardly any of it is flat. With loaded tires and box blade on the back, I have to stay in medium almost the whole time. I can use high when going up the street but really have to rev the heck out of it.
You will most likely hear quite a bit of "whining" from the transmission on the hills. As far as maintenance, I just changed my hydraulic fluid and filters, cost me $350 but I won't have to change the fluid for another 400 hours.
There is very little maintenance and for loader work an HST is tough to beat.
   / Hydrostatic transmission for hilly land? #10
Make sure it is a three range hydro! With two range you will be in low all the time and that is with about a 4mph max speed where a three range would give you about double that in the middle range and still have good power.
2012 Chevrolet Silverado 2500 HD Enclosed High Top Service Truck (A52377)
2012 Chevrolet...
2017 Kubota KX080-4 Mini Excavator (A51573)
2017 Kubota...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
100 GAL FUEL TANK W/PUMP (A52472)
100 GAL FUEL TANK...
New Wolverine Skid Steer Tiller Attachment (A53002)
New Wolverine Skid...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
