I Just Got a New Air Compressor
   / I Just Got a New Air Compressor
...One thing's for sure - if you go with the 5 horse, you're most likely gonna need to fab a new belt guard once you've got it dialed in... Steve
I thought about that as I was falling asleep last night. I'm probably going to just use one of the 6" pulleys that I have lying around for now on the 5 hp motor. I won't be getting the full advantage of the 5 HP motor, but I won't have to modify the belt guard. I can get a larger pulley later if I want.
   / I Just Got a New Air Compressor #22
Here's the spec sheet on my compressor - just to muddy the waters some more :confused:
You posted while I was typing - I think that would be a good place to start, for all your reasons and a few of mine :=)
Thanks for all the help. I brought the motor home tonight. I am in the process of mounting it to the frame. The holes don't line up so I'm making brackets.
You electrical gurus out there prepare for wiring questions. The next step is to wire the pressure switch and mag starter.
I forgot to mention that none of my pulleys would mate with the motor. Since I had to buy another pulley anyway, I bought a 7.4" diameter one. That should give me a lot of air without pushing the limit on speed of the compressor.
Status update...
I have the motor mounted to the tank, and about half of the wiring done. All the wiring is cobbled together from stuff I had laying around. I have the pressure switch wired to the coil for the mag starter, and I have a separate overload switch before the mag starter.
I added the extra overload because the mag is rated at 7.5 KW, and I'm not sure it would effectively protect the motor.
The garage is a mess!! I had to move most of what's in there to get this compressor into place.
   / I Just Got a New Air Compressor #26
Sounds like you don't need us "electrical gurus" after all :thumbsup:
Things I'd do next with that setup (don't take offense at any of this - my friends kid me about not being able to buy/get ANYTHING without modifying it :laughing: )
1. Find a way to protect that gauge on the end from "heat of battle" moments, BEFORE it gets knocked off (without welding on a pressure vessel, of course)
2. Hopefully that tank has a threaded hole at or near its lowest point - my tank is vertical, and has a bottom drain. I added one of these
New Electronic Auotmatic Tank Drain for Air Compressors - Amazon.com
Got it set for about 5 seconds every hour, and (unlike me) it doesn't forget :confused2:
With a horizontal tank, if necessary I'd shim up the end AWAY from the drain an inch or two just to be sure. Cheaper than buying a new tank or dealing with REALLY wet air.
3. To reclaim some of the lost space, I would look at hinging a "medium duty" bench top to the wall above the compressor, with drop-down legs so I could get to it for any repairs/changes without needing a fork lift (although in my case, it'd probably take me half a day to EMPTY the bench so I could raise it out of the way :rolleyes: )
Use any, all, or none of these - my suggestions are (usually) worth at LEAST whatcha paid fer 'em :D
Get ready to enjoy NOT waiting for the compressor - unless you're sandblasting with a half-inch line, I doubt you'll need more air... Steve
I'm still not sure that is where the gauge is going to go permanently. After moving the compressor into place I realized it might be nicer to have the gauge higher where it is easier to see.
I put a new drain in the tank, but I hadn't thought about tilting it. I may just do that. The idea of an automatic drain is nice, but I currently have only $61 into this whole contraption. It's hard to justify the extra $100. For now I'll just have to set reminders and drain the water regularly.
I may re-organize that peg board above the compressor to make better use of the different space. The real problem is my lathe. The right 2 feet of the new compressor is in space that used to be occupied with the Lathe. I don't use the lathe much anymore. I may just find a place to store it for now and figure out a home for it after I get my new workshop built.
Thanks for all the suggestions and help. This is why I love this site.
   / I Just Got a New Air Compressor #28
Another suggestion, if you mount the tank feet to 4 X 4 's or 6 X 6 's you will get less vibration and you can shim it for tilting.
The tank us on rubber feet. Will the boards still help?
   / I Just Got a New Air Compressor #30
If the rubber feet are original equipment for that compressor/tank, probably won't help with sound level but would still help if you want to tilt the tank for better drainage -
If the rubber feet are someone's attempt at quieting, they could be either helping, hindering, or neither.
This gets into the realm of mass-spring-mass calculations - ever seen a sign on a long suspension bridge that said "no dogs allowed"? This isn't because the bridge maintenance crew doesn't wanna clean up your pooch's messes, it's because of RESONANCE. (Another term for mass-spring-mass effect) -
In the case of the bridge/dog, typically a dog will go into a trot when it's going somewhere - it's a very constant series of "little jumps", so to speak. If that particular dog's weight and "frequency of thumps" happens to coincide with a harmonic of the bridge's natural resonance, it works just like pushing your kid on a swing - if you time the pushes right, he'll go higher and higher. In the case of the bridge, there have been cases of dogs destroying a bridge under the wrong circumstances.
In the case of your compressor, the air pump will have a specific resonant frequency based on rpm (which you just changed by changing motor speed slightly, and pulley ratio) - the mass of the entire unit also enters into the resonance of the device - the rubber feet are the "spring", and the earth (considered infinite for calculation purposes usually) is the other "mass" - hence the "mass-spring-mass calculation.
There are two instances when a spring is NOT a spring - these are at either end of its travel. So if the rubber feet are compressed enough (due to being too small or soft or both) then they are no longer "springs", and might as well not even be there.
If those rubber feet are the wrong hardness (called shore value) they will either compress too much, or not enough - they need to be near the middle of their range between uncompressed and flattened to work well. If their travel during "thumps" of the compressor gets too close to either end of their range, you'll get noise transfer to whatever the compressor is sitting on. Once it gets to your floor, part will be deadened by the earth under the slab and part will transfer to walls and ceiling, which will amplify the noise (typically)
Oh man, just realized I drifted into "auto" mode - sorry. Did I mention that I do some acoustical consulting from time to time? :confused2:
Shorter answer - oh yeah, that was the FIRST sentence :D ...Steve
(3) Air Hose Reels (A51573)
(3) Air Hose Reels...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
2000 KENWORTH T800 (A52472)
2000 KENWORTH T800...
Airco Tig Welder (A51691)
Airco Tig Welder...
2024 JOHN DEERE 9R440 LOT NUMBER 78 (A53084)
2024 JOHN DEERE...
2013 FORD F650 ROUSTABOUT (A52472)
2013 FORD F650...
