Iplayfarmer
Super Member
I've had the pump running for a few seconds at a time and it's pretty quiet.
Yup, blowing down the outside water is one of MANY uses our compressor gets to do, along with (wife) cleaning out the vacuum cleaner and rug machine, etc -
It's gotten to the point where wife and I BOTH are only half joking when either of us comments that "if either of us AND the compressor dies at the same time, guess which one'll get replaced FIRST :laughing:
I do have an overpressure pop-off valve right above the pressure gauge that should protect me from the shrapnel scenario. I'd really rather not burn up the pump or the motor, though. In my stash of fancy process control components I have a few timers. I have considered wiring a timer into the control side of the mag switch that will automatically turn everything off if the motor runs for an unusual amount of time. It would be overkill if I had to buy the parts, but I have them, and I don't have any other use planned for them.I'd be a bit cautious going too high - if it IS a water pump switch, the diaphragm may not be rated much over maybe 100 psi -
If the diaphragm ruptures, not only will it keep the compressor running, (the switch would think you had ZERO pressure)but if the resulting hole isn't bigger than the compressor's capability, pressure will build until the NEXT wimpiest thing blows.
Hopefully that would NOT be the TANK (can you say "shrapnel"??!?)
If the resulting hole IS bigger than the pump can keep up with, it'll just burn out your motor. Neither situation is good for morale
If you're not sure, one temporary solution (kind of a PITA) would be to ONLY turn on the compressor when you're gonna use air - at least that way, someone will be there if/when she blows... Steve
