Ford says no to Diesel F-150
   / Ford says no to Diesel F-150 #191
Yeah, I know it was slated for the 1500. I just think it's overkill for a half-ton truck. Heck, the 1st Duramax had what, 300/500? I know the first 6.0 from Ford had 300/550!
Not over kill at all, look at the tow ratings of the new 1500. 400 is not near enough,
300/520 was the LBZ.
   / Ford says no to Diesel F-150 #194
No, not overkill. They are evolving. But a car if you want a grocery getter.
I can use my 3/4 ton truck for a grocery getter (and I do on occasion). It's a multi-purpose truck used to take my kids to school, pick up groceries, haul our fifth wheel, etc. It's a diesel with 350HP and 650 ft-lbs of torque, and I would trade it for a 300 HP, 520 ft-lb 4.4L diesel if there was one available. I just don't need that much power for my trailering duties. I'm not saying that nobody does, I just don't.
However, I don't think a half ton truck needs to be able to tow 11k lbs. Seriously, that's just overkill. If you need to tow that much, that's what 3/4 ton trucks are for. Let's put a little focus back on fuel economy and forget about the towing and HP pi$$ing matches for a while!
Of course, that's just my opinion...
   / Ford says no to Diesel F-150 #195
I agree!! Enough with the power wars, cap the power, and start building for economy.
But will they listen?
   / Ford says no to Diesel F-150 #196
I agree!! Enough with the piwer wars, cap the power, and start building for economy.
I think Dodge (errr, Ram) is starting too. Look at the latest iteration of the Ram half tons. Tow ratings down, fuel economy up, EcoDiesel coming.
I really have high hopes for the next F150 coming in '14. I think we will see some really impressive fuel economy numbers from Ford next year. The competition will be great for everyone!
   / Ford says no to Diesel F-150 #197
Yupp!! The. New DI 5.3 from gm has improved mpg, only a slight bump in power too!!
The '14 won't be out til December but it is the same as the '13. The '15 will be the new one.
   / Ford says no to Diesel F-150 #199
By '14, I meant the calendar year. ;)
The '15 (model year) should be revealed at the NAIAS in Detroit in January '14 with production starting at the Dearborn Truck Plant in June '14. Kansas City Assembly Plant will produce the '14 until December '14 when it goes down for retooling.
   / Ford says no to Diesel F-150 #200
Amen, you must be a thinking man. Or at least give us more common sense choices.
Mohawk 12,000lb Two-Post Electric Auto Lift (A54811)
Mohawk 12,000lb...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A53473)
2-Row Peanut...
TOOL CART (A53843)
TOOL CART (A53843)
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
1995 Ford L8000 Grain Truck GARAGE KEPT (A53473)
1995 Ford L8000...
MURRAY PUSH MOWER (A53843)
MURRAY PUSH MOWER...
