Need to cut a nice round 4" diameter hole in the end of steel barrels.
   / Need to cut a nice round 4" diameter hole in the end of steel barrels. #1
pharmvet
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
Every time about this time of year we replace a few of the barrels in our deer feeders. The new barrels need to have a 4" diameter hole cut in the center of the bottom in order to be used as a deer feeder (our funnels and motors attach there). In the past, we have always borrowed a neighbors Greenlee 4" slugbuster knockout punch. It worked wonderfully. He died a couple of years ago and the punch vanished. We will need one from now on, so we have began searching for one. As you probably know, they are pretty expensive. Any thoughts or suggestions on where to find a good used one? Also, I have noticed that the ones sold for 4" conduit actually make a hole larger than 4". I need a 4" hole. Any and all recommendations welcomed. thanks
   / Need to cut a nice round 4" diameter hole in the end of steel barrels. #2
Hole saw? I've used a 3" hole saw before with good success. Best to use it on a drill press, but if you must use it on a handheld drill, keep the RPMs as low as possible. With that large diameter, you will quickly heat it up. 100-200 rpms is best, if you can manage it.
   / Need to cut a nice round 4" diameter hole in the end of steel barrels. #3
Hole saw will work in a heavy duty drill. If you only have a couple to do, it will work, though not fun. I recommend a helper dripping oil on the cut and both of you will want earmuffs!
   / Need to cut a nice round 4" diameter hole in the end of steel barrels. #4
Alternative: Jigsaw. Use a nice bi-metal blade if you want to really go all-out. Just depends how exact the circle needs to be.
   / Need to cut a nice round 4" diameter hole in the end of steel barrels. #5
Use A bi-metal hole saw with a pilot bit.
Yes, A greenlee 4" punch would probably be about $300 by now, or more.
   / Need to cut a nice round 4" diameter hole in the end of steel barrels. #6
Also use cutting oil, it will cut down on noise and help the cut be easier to make! LUTT
   / Need to cut a nice round 4" diameter hole in the end of steel barrels. #7
+1, What I have done when using larger diameter hole saws is cut a piece of foam rubber the size of inside diameter.
Also the same depth of hole saw, I then pushed it in hole saw to slide of pilot bit, then removed and saturated with oil, then place back in hole saw.
As you drill, the foam will compress and automatically release oil as needed.
Good Luck
   / Need to cut a nice round 4" diameter hole in the end of steel barrels. #8
Good Luck
I like the foam Idea, I have a 4" hole saw works good, but look for a Bi-Metal one. I think I got mine from Grainger when doing a job where we needed to pit in a 4" exhaust hole for a hot water heater at work. Put it on works account and ended up keeping it in my locker where I used it 2 or 3 more times. When I left all the tools were given to me as mine so I got to keep it...
Mark
   / Need to cut a nice round 4" diameter hole in the end of steel barrels. #9
   / Need to cut a nice round 4" diameter hole in the end of steel barrels. #10
Harbor Freight 3 Piece Large Diameter Bi-metal Hole Saw Set
Warrior - item#68989
Sale: $17.99
3", 4", 41/2"
Bi-metal Hole Saw Replacement Mandrel
Portland Saw - item#68118
$6.99
2015 Ford F-550 XL (A50120)
2015 Ford F-550 XL...
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
2012 Chevrolet Equinox 1LT SUV (A50324)
2012 Chevrolet...
2011 Manac 36245B30 45ft T/A Walking Floor Trailer (A50323)
2011 Manac...
2012 Peterbilt 337 IMT 6025 14,000lb 5 Ton Crane Mechanics Truck (A50323)
2012 Peterbilt 337...
