Building a pond on my property to stock fish
   / Building a pond on my property to stock fish
This pond is for my enjoyment and so will be the fish
Here is a funny story for you. I have an artisan well that produces 30gpm at 132ft just down from my pond, so I dug down another 30 ft at the bottom of the pond. I did not hit the water table so I filled the 3ft x 6ft hole that I dug and compacted it with the bucket as I went. I filled the pond for 3 weeks 24/7. I had the pond about 2/3 full when the water found its way to the water table through the hole that I had previously dug. The pond emptied itself overnight. I have now let the pond sit for 2 years to recompact the clay based soil naturally. This next spring I am building a man made creek and waterfall to aerate and circulate the water. I my natural compaction does not work I will have to line the pond, but I am hoping that I will not have to do this. I do not like lined ponds.omh pro screen usa 4 10 2010 122.jpg
   / Building a pond on my property to stock fish #14
Here is a funny story for you. I have an artisan well that produces 30gpm at 132ft just down from my pond, so I dug down another 30 ft at the bottom of the pond. I did not hit the water table so I filled the 3ft x 6ft hole that I dug and compacted it with the bucket as I went. I filled the pond for 3 weeks 24/7. I had the pond about 2/3 full when the water found its way to the water table through the hole that I had previously dug. The pond emptied itself overnight. I have now let the pond sit for 2 years to recompact the clay based soil naturally. This next spring I am building a man made creek and waterfall to aerate and circulate the water. I my natural compaction does not work I will have to line the pond, but I am hoping that I will not have to do this. I do not like lined ponds.View attachment 331002
We ran into the same problem. I wanted to get it deep enough to dive into, so we dug down a couple more feet in one end of the pond. We dug through the clay and hit sand. As much as we tried to patch it up with clay, we couldn't make it hold water. Like you, we have an artisan well. It has a good flow, but it would all run out. What we did was put a few hogs in there and scatter shelled corn on the pond bed. We were told the rooting around would help seal the clay. But two months later, the Chipola River flooded and the pond held water after that. Not sure if the hogs helped or not.
   / Building a pond on my property to stock fish #15
In my experience, the ground between the bottom of your pond and the water table needs to get saturated before the pond will hold water for long periods.
Also, hot and windy days can evaporate an inch per day. You could lose 2 1/2 feet in one hot dry month.
   / Building a pond on my property to stock fish #16
I thought that soil looked pretty light with no clay base , If it were me I'd drop about 10 large loads of clay in the bottom and let it settle over the winter and with your nw Pa winters it would probably stay filled come spring ? a local neighbor dug his 4 years ago and it finally held water this year .:thumbsup:
omh pro screen usa 4 10 2010 120.jpgwhat you are seeing is 2 inches of topsoil on top of the clay. I was not going to finish the pond right after I built it so I spread soil to grow good grass and not bad weeds. Here is the type of clay that I have to work with.
   / Building a pond on my property to stock fish #18
looks pretty light ,if you pick it up can you make a "snowball" out of it with out it falling apart when thrown hard , that would be good clay .
   / Building a pond on my property to stock fish #19
To the guys with the "holes" in the bottom of the pond see if you can find some Bentonite clay, it is used in drilling wells and sealing it all up. It can be bought in bags and maybe contact local well driller to buy some.
Otherwise you can also add some heavy mil plastic sheeting or EDM rubber roofing over the areas that you suspect are leaking and add a layer of clay/sand on top..
M
I have used bentonite before and that may be the direction that I have to go. I usually mix it about 8 inches deep, compact the surface, and then cover it with about 6inches of heavy rock to keep the water from moving the bentonite.
2006 MOXY MT41 OFF ROAD DUMP TRUCK (A52707)
2006 MOXY MT41 OFF...
2004 Caterpillar D5G (A53317)
2004 Caterpillar...
UNUSED RAYTREE RMBD72S 72" HYD DRUM MULCHER (A57193)
UNUSED RAYTREE...
2023 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2023 Ford F-150...
UNUSED FUTURE FT-FR60 60" SIDE SHIFT FORKS (A57193)
UNUSED FUTURE...
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
