Thinking about a winch to mount on my new deck over.
   / Thinking about a winch to mount on my new deck over. #1
Timber
East Bridgewater Massachusetts
Kubota B7800
We are having our tax free weekend here in Massachusetts. I think I'm going to pick up a winch for the trailer at tractor supply or northern tool. Either a 6000 or 8000 lb winch. Any thoughts or opinions.
   / Thinking about a winch to mount on my new deck over. #2
I have a $99 4000# winch I bought through Rural King.com 8 or so years ago. Its never failed to pull what will fit on my 7000# 18' trailer. Its pull well over 50 things up, largest was a Suburban and a 45 HP tractor with a FEL.
I think 8K is overkill for a 7K trailer. Especially if you use a snatch block. Remember, ratings are dead pull, not rolling.
Chris
I was looking at the badland 6000 lb winch at northern freight today. I'm sure that will be enough, I just bought a new jump box too last week.
I picked up a 6000 pound Badlands winch at Harbor Freight and a portable winch mount for the new deck over trailer. I am a very happy guy, I'll be able to winch all my trucks, the tractor and my van not to mention the trailer. I also recently purchased a jump box that I didn't realize can power the winch on all my machines independently. I love it when things come together on a tax free weekend.
   / Thinking about a winch to mount on my new deck over. #5
Congrats on the new winch and trailer. Always feels good to keep some of that hard earned $$ in your pocket without having to hand it over to the Federal Government. Glad you had a good tax free weekend.
   / Thinking about a winch to mount on my new deck over. #6
Don't forget to have a snatch block handy to double the line for pulling the heavier vehicles. (I like the ones TSC (Tractor Supply Company) carries. It is quick & easy to setup. Just twist the plates, slide in the cable then twist the plates back together.
I also have a Harbor Freight wireless remote for the 12,000 winch so I can steer while loading easily. NOTE: there is a 2-3 second delay from the time you release the button on the remote before the winch stops moving.
I have my winches mounted to 1/4" thick steel plates welded to 1/4" walled - 2" sq tubing that will mount into receiver hitches. It is mighty handy. I welded 2 1/2" tubes to the front of my trailers to for quick connecting /disconnecting. This way the winches can be stored out of the weather when not needed.
To make quick wiring connections I use the same type you find on welding leads. I have a set wired to each of the batteries mounted on the trailers & have a pair of jumper cables with these connectors on one end.
I have a 12,000 lb Badland, 6,000 lb, 3,000 lb, & 2 - 2,000 lb winches.
Note on my 12,000 lb winch, I have a 1" spacer between the winch & the steel plate for the times the cable does not wind up evenly.
Great Tool!
   / Thinking about a winch to mount on my new deck over. #7
The 2" receiver quick mount is about the best thing anybody came up with for a winch (I thought I invented it years ago haha!)
My first mount was built out of thick walled tube on the tongue of the trailer, triangulated and reinforced. You could have winched a tank from that position...a bit too much for an 8k winch LOL. Later I found that the 14.99 bolt on receiver mount from Harbor Freight works just as well when properly bolted or welded. Its a very sturdy piece.
Id like to integrate one of these inside a trailer toolbox somehow to protect it from the elements.
Oliver, nice idea on the welding lugs.
2023 John Deere 8RX 370 Track Tractor (A53485)
2023 John Deere...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2013 MACK ELITE LEU633 GARBAGE TRUCK (A57192)
2013 MACK ELITE...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
1339 (A57192)
1339 (A57192)
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
