Rear Axle Seal Housing
   / Rear Axle Seal Housing #1
roy weidner
Thomasville Ga
Yanmar 1500
Broke this bolt on piece to a Yanmar 1500 Red . Can I simply pull the rear wheel and replace?
   / Rear Axle Seal Housing #2
What???
I dont understand your question? Did you brake the bolt that holds the hub on? IF you have a broken bolt your going to have to get the bolt out of where its broken.
I think we need pictures here for this one.
   / Rear Axle Seal Housing #4
Winston I'm betting its #35 he broke. I'm curious what he was trying to fix when it broke.
   / Rear Axle Seal Housing #5
That would be my guess too. Maybe trying to tighten it up to stop a leak? :confused3:
   / Rear Axle Seal Housing #6
If its a leak there he has more problems. That's a dry housing.
The bolt on piece #33 broke on the left side and the top bolts #35 broke both left and right sides
   / Rear Axle Seal Housing #8
No, it broke becasue there was a makeshift roof attached to the fender. The fender bolted to the top two bolts of the seal housing. The driver got the roof caught up in a limb that tore the roof off. Breaking the bolts holding the roof on and breaking the top half of the seal housing.
   / Rear Axle Seal Housing #10
Ah ok. You will need to remove the hub. # 28 in the axle internals picture. It's held on by the one bolt. I needed to use a puller to get mine off. Then you can replace the broken housing and the seal. It's a dry axle but there is a seal there to keep out dirt. You may find you also need the sleeve the seal rides on too. Also there's a paper gasket. Some sealant there would be fine.
2011 NORMAN POWER SYSTEMS 100KW GENERATOR (A52472)
2011 NORMAN POWER...
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
2015 FORD F-550 SUPER DUTY (A52472)
2015 FORD F-550...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2015 TEXAS PRIDE  GOOSENECK (A52472)
2015 TEXAS PRIDE...
