cat 5 / 6 coupler? ( plug 2 cables together to get extra length? )
   / cat 5 / 6 coupler? ( plug 2 cables together to get extra length? ) #21
I am using the simple inline couplers in a IP camera run, including PoE, no problem. The total run was only 100' or so, and I just needed to extend about 15'. Works fine.
Lowes also had some that connect through a wall plate, with a double female in the plate, so you can plug one male in behind the wall, and another into the front. Not a purist's first choice but better than pulling another 100'. If you were out near the spec max of 100 m for Ethernet it might be more of a compromise, but in shorter runs it works. And it's certainly cheaper to try it first- you can always use a 15' network cable somewhere else if it didn't work out.
We finally got them to let us run three CAT5s on each run. Two for data and one for phone. That's worked OK over the last few years, but it would have been more cost-effective to do it all at once. Hindsight is 20-20 of course, but we did have a glimpse into the future back then and they should have seen it coming.
Around here it's hard to even get a request on the budget agenda. ie. we know we NEED something.. and yet they will set onthe idea till near too late to decide if they will decide on doing something at all.
Kinda like having a meeting to decide if you will start bailing out the ship, while you wait to have the meeting do decide if you will fix the hole in the ship.
i see those double female connectors that are couplers.. but also will click into a wall plate. now that would be a nice idea. push the 2' stub back into the wall, install a connector plate and then install a? 15' or whater patch line.
assuming we go for this next project.. I believe that is what i will do.
thanks for the discussion guys.
I'll update tghe htread and let you know the turn out. someday.. ;)
   / cat 5 / 6 coupler? ( plug 2 cables together to get extra length? ) #24
The double female wall connector sounds more asthetically pleasing than an in-line splice.
sure does. and I just priced them. not but a buck or so mor ethan a straight smooth type
   / cat 5 / 6 coupler? ( plug 2 cables together to get extra length? ) #26
Sounds like you have a winner. :thumbsup:
   / cat 5 / 6 coupler? ( plug 2 cables together to get extra length? ) #27
Unless you want a Snickers bar, then you should save that dollar! :licking:
speak of the devil. building manager just came down and asked me to resend all the quotes and my recomendations to him again and that he had preliminary approval for purchas. he would re-submit the info again for final approval ( tomorrow? ) and then let me know via email when to start ordering.
wow... :)
   / cat 5 / 6 coupler? ( plug 2 cables together to get extra length? ) #29
Someone's ears must have been itching.
OR MY CUBICAL IS BUGGED.. :) / READING MY EMAILS. :)
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
Cushman Electric Cart (A55853)
Cushman Electric...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A55314)
2022 New Holland...
Honda EM3500SX Portable Gasoline Generator (A55851)
Honda EM3500SX...
2021 Club Car Carryall 500 Utility Cart (A55851)
2021 Club Car...
2023 RAM 3500 4DR 4X4 CAB AND CHASSIS (A56138)
2023 RAM 3500 4DR...
