2014 chevy cruz diesel
   / 2014 chevy cruz diesel #61
I still think that GM is missing out by not offering a manual. No, not a manu-matic flappy paddle thing, but a traditional manual. It would allow you to get the most out of the engine. I think it would change the car;s feel completely.
Our old Jetta TD was very satisfying with the manual.
Agreed they didn't seem to do their research on vw tdi owners
   / 2014 chevy cruz diesel #62
The Cruze eco manual has one of the highest rated EPA highway milage for non hybrid gas engine at 42 mpg it ties the vw diesel. So what if its not a gdi engine. that high pressure fuel pump is something people complain about in diesels when it comes time to fix it because they are so darn expensive. The ECO will generally give 43-46 mpg at 70 - 75 mph on summer fuel.
Hi Dave - just to clarify - even if I won a lottery, I'm in no particular rush to buy a DI gasoline engine. If I had to buy a new gas car tomorrow, it would be MPFI, for the reasons you list, amongst others.
While I have a strong interest in most forms of technical advancements, I prefer to spend my money on mature technologies like MPFI.
And.... I do get irritated by the tremendous increase in complexity, with little or no improvements in certain areas of performance. IE. Bosch mechanical gasoline fuel injection systems were delivering close to these mileages, in the late 1970's !
So yeah..... I'm more than OK with certain older technologies, and not automatically impressed by new tech "advancements".
Rgds, D.
   / 2014 chevy cruz diesel #63
As much as I like to see stick tranis offered..... if I was a VP of Marketing at GM, I wouldn't be in a big hurry to try and take on VW directly - tough competetion in this sector.
That last design article I linked gives an indication of the marketing spin GM wants on the diesel Cruze - "It's a performance engine (agreed) that happens to get pretty decent fuel mileage".
As "spin" goes, I can live with that marketingeze (as it's true).
In this case, the "Take it for a test drive, and see what you think" strategy is a pretty good one..... torque is easy to sell ! :D
Rgds, D.
   / 2014 chevy cruz diesel #64
Id love to know the percentage of VW owners in general who choose the stick. And what subset of diesel owners did as well. I bet its high.
Also love to see the breakdown of transmission choices for Canadians vs Americans
   / 2014 chevy cruz diesel #65
The TDI, in my mind, is VW's best engine. We rented a 2.5 gas one once to drive back from Columbus to Charlottesville after taking a rental truck over. Didn't like the 2.5 at all. Never driven the 2.0 liter turbo gas one, but it has no where near the torque.
The TDI goes up the WVa mountains as though they're not there. Maintains cruise control speed up every one in 6th gear. My Tacoma pickup required 3rd gear on two of those mountains and, of course, would not maintain cruise speed.
It's like driving a VW with 2 cylinder thirst. Absolutely love it.
I second the motion of one responder who wants to see a small pickup with a 2.0 liter turbo diesel in it. Our old 1996 Tacoma with a VW TDI in it would be a wonder performer and would yield 50 mpg, as it was only 3,000 # (250 less than a Jetta). (Have a sorry 2005 Tacoma now; it's the one that won't make it up those WVa mountains other than 3rd gear; the older Tacoma would squirt right up the mountains and still yield 30 mpg.)
Canada may get the VW Amarok diesel pick up!!
   / 2014 chevy cruz diesel #66
The stick still exists in some North American vehicles only because it was already engineered and manufactured for markets outside of the US and Canada . The typical North American driver doesn't know what a clutch pedal is for. The military went to all automatics a decade or two ago because recruits were grinding gears and smoking clutches.
Some people worry about GDI diluting lube oil or carboning the intake valves due to dry air in the intake port.Or concerned about the 2000-3000psi common rail injection system. Last time I checked diesels were direct injected and have no fuel flow through the intake port. Few people are concerned about lube oil dilution or stuck intake valves.2000-3000psi is the relm of the old diesels and not a serious problem. The new 20,000+psi common rail EPA diesels have injector problems.
   / 2014 chevy cruz diesel #67
Rgds, D.
Okay i misunderstood i thought it was a technology you were regarding as the price of entry for considering a new car. Another interesting fact about the 1.4l turbo is that gm went back to an iron block. While this is mainly to help with engine noise as gm has been plagued with horrible noise and vibration on their aluminum block 4 cylinders for years. They were also able to keep the mass increase down to a minimum by optimizing the block design for that bore diameter. Because they don't need to sleeve an iron block the iron block is considerably smaller than the aluminum would have been.
I should provably disclose I'm a performance engineer at GM who works on the cruze platform. I've spent a lot of time in the eco and love it. If my wife didn't work for ford i would own an eco manual. We ended up getting a focus to add some balance to our fleet of 5 GM vehicles. I own 4 cars/trucks that are 96 and older. 2 1996 gm trucks first year for multi port once you upgraded from the central port. I'm not necessarily a fan of new technology either. I like being able to work on my own stuff.
Heres how i spent my weekend I'm retiring her with close to 200k the rear body structure was shot due too MI winter roads and chloride on the dirt roads. im saving all the usefull parts for my wife's 1995 sc1 with 235k miles. This is a summer only car for here. The engine and trans are under the car.
Sorry i didn't understand where you were going in your original post.
   / 2014 chevy cruz diesel #68
Canada may get the VW Amarok diesel puck up!!
I'll keep my fingers crossed Will, that would be fantastic.
They might even be testing the market here, to see what the uptake is, before launching in the USA. A little easier sell with our fuel prices being higher, and diesel fuel typically priced a little lower than gas here.
Rgds, D.
   / 2014 chevy cruz diesel #69
I understand your points BaD.
I don't recall any recent post from you about it, but like many gearheads, I wouldn't be surprised if you enjoy driving a manual. That's my deal, it's a personal preference, that typically (with my driving style) yields better than automatic fuel mileage. Never been one to follow what the masses are doing, unless it actually meets my needs/wants/budget/maintenance profile.
I've got this funny attitude about buying a new vehicle. If I'm going to spend THAT much money, I want exactly what I'm after. I was chatting with a salesman in a dealership about the limited and boring colours available on cars - his response "That's what people want". Do I want to drop $30k+ so I can drive a beige car ? Guess I'm just one of those lemmings, who heads the wrong way ! :D
The new automatics are impressive on paper, and can deliver good/great fuel mileage on some platforms. I somebody is a Lease for 90k km Then Dump It type, then the rest of the story doesn't matter. I tend to Buy and Hold vehicles for a long time. Honda and Hyundai, and VW have had some spotty reliability on their automatics, to name just a few.
Maintenance - for cost reasons alone, a person would be wise to understand the price of changing the fluid in VW's DSG automatic. That, and it has to be done fairly often. Great design, but a lot of the fuel saving (vs. older automatics) is going to get chewed up by the service costs.
IF I found a used vehicle in truly fantastic shape AND it was automatic AND I could get it for a steal, then I might jump on it. Buying brand new, it'll be stick for me, at least for small/mid-sized cars.
Given the long service life I can get out of a stick transmission in my household (fully understanding that is not common, today), I have no particular interest in getting into owning a more complex transmission that costs more to maintain, and in may cases is significantly less reliable than a manual.
I'm from Missouri, with a stutter and OCD loop built in, when it comes to proving new technologies, esp. when it can potentially hit me hard in the wallet. One of my concerns is gasoline quality, there are some issues in that area, and not just with the present and escalating level of ethanol. The lousy lubrication of ethanol is not something diesel owners have to deal with, unless they are not paying attention to what additives they are using.
At a minimum, if I owned a GDI vehicle, I'd be doing some reading over on BITOG to see how prevalent fuel dilution is. If it was common, I'd be getting testing done on my own oil. I'd also be checking to see if this particular GDI has a discrete and readily changeable fuel filter - if not, I'd be keeping in mind that performance and problems may change over time, as deposits build up somewhere other than in a fuel filter.
GDI is impressive in many respects, it's just not something I'm interested in spending my money on, yet.
Rgds, D.
   / 2014 chevy cruz diesel #70
Thanks for the apology Dave, but No Worries, Eh !
Good to have a factory guy hanging out here, esp. one that spends personal time spinning wrenches.
I noted that Return to Iron Block useage..... funny, if you follow designs for long enough, things often get recycled.
With the wife driving Ford, does she fix her own car ? :laughing: The older Focus had some wonky suspension issues, but for the most part weren't too bad.
I can understand that you aren't totally free to talk about behind-the-scenes design issues and trajectories, but we look forward to whatever insights that you can share.
Rgds, D.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
206707 (A58375)
206707 (A58375)
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
Mini Skid 6 Way Blade (A56438)
Mini Skid 6 Way...
