ovrszd
Epic Contributor
- Joined
- May 27, 2006
- Messages
- 32,246
- Location
- Missouri
- Tractor
- Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
I appreciate the links and photos' as I am gathering materials for this right now. I would prefer to use the drawbar to pull the box as it is closer to the axle than the 3ph linkage. I will build this with a tilt cylinder in addition to the rear height control cylinder, both of these circuits will be operated through a proportional electric solenoid valve tied into a Topcon automatic machine control setup. I had been playing with the design some and pictures showing how to clear the raised scarifiers really helps save some time. Currently I have three rear remotes, one for the tongue, one for the scarifiers and the last for the two proportional valves working together. This way I can unplug the topntilt cylinders and raise the IMatch up and out of the way with the rockshaft, then plug in the boxblade and go.
The Topcon equipment and Sauer Danfoss valves are definately causing me some financial strain so anything I can do to cut the cost on the boxblade whle doing this is important.
I think I'll go with the tongue on the 3pt and two cylinders setting the rear wheels to get tilt. One thing I know from 20 years of grader operation. You need the cutting edge of the blade as close to being centered between the rear wheels on the blade and the rear wheels on the tractor as practical. The one pictured is way off from that and won't cut off high spots and fill dips nearly as well as if centered. So for me, the tongue needs to be as short as possible and the wheel brackets then built long enough to center the cutting edge.
