Help - won't start due to idiotic move on my part! Stood up with PTO on!!!
   / Help - won't start due to idiotic move on my part! Stood up with PTO on!!! #1
smcglon
Pike Road, AL
Kubota MX 5100
I have a 2010 MX5100 Kubota. Like an idiot, I got up with the PTO engaged this past (w/6' JD Bush Hog attached) Saturday and the tractor shut down. Turned PTO off and tried to restart and it seems the entire electrical system is half on. A faint buzzing sound is coming from below dash when I turn the key on. When I turn the key once more to start, all lights go out - nothing. Battery is good, wiring is good, checked all fuses (all good), checked safety switch on seat (seems to be good and correctly working). Acts like there needs to be a breaker reset - or something related but I have no idea. Even with the tractor on, the flashers barely turn on. What is even stranger - I can leave it on with the faint buzzing for 30 seconds, turn it off and then turn it back on, all the regular check lights turn on but when I go and turn the ignition once more...nothing and it goes back to the fainting buzz sound. Can't find anything in the manual. Sitting in the middle of my pasture dead. HELP! Thanks, Scott
   / Help - won't start due to idiotic move on my part! Stood up with PTO on!!! #2
Sounds like you have a bad battery ground or a weak battery not providing 12 plus volts. Have you checked the battery?
   / Help - won't start due to idiotic move on my part! Stood up with PTO on!!! #3
This was my thought as well. Bad ground - remove and clean both ends of ground cable.
   / Help - won't start due to idiotic move on my part! Stood up with PTO on!!! #4
Dose sound like the ground, or maybe the positive connection.
   / Help - won't start due to idiotic move on my part! Stood up with PTO on!!! #5
Battery or ground, did you try jumping it?
   / Help - won't start due to idiotic move on my part! Stood up with PTO on!!! #6
Did you also check the solenoid? Put a voltmeter at the point where the wire from the solenoid attaches to the starter; then have someone turn the key to start. If it does not read 12 volts, you have eliminated the starter motor as the culprit.
   / Help - won't start due to idiotic move on my part! Stood up with PTO on!!! #7
Was the PTO actually disengaged. I have stalled a couple of times while mowing and even though I had returned the PTO lever to the disengaged position the engine wouldn't start. Seems that there was pressure on the PTO somewhere, the lever was disengaged but internally it actually hadn't disengaged. By thumping that lever it eventually released.
   / Help - won't start due to idiotic move on my part! Stood up with PTO on!!! #8
Those cables on the pto are problematic. Climb under your tractor and trace the cable from the pto lever to the point where it connects to a lever on the (right) side of your transmission. Take your finger and push forward toward the front of the tractor. The lever should move easily and probably no more than a quarter of an inch. You should be able to start your tractor. If it does then adjust your cable. If this doesn't work then you might have a faulty seat switch or a short.
Thanks for all the feedback. Heading to the pasture now to try it out. I have checked the battery (new) and the cables so I am pretty sure it is not the battery or ground but will triple check.
RB - thanks for your input. The "pressure" on the PTO sound like it could be the culprit. The tractor was running great, I engaged the PTO/bushhog so it was spinning at idle speed, and then took it out of gear to get off forgetting to disengage the PTO. The tractor shook and cut off as soon as I stood up. The tractor was off when I disengaged the PTO. If the seat switch shorted out, is there a way to circumvent the switch? Any other ideas? Thanks again for all the feedback - this has been great! Scott
   / Help - won't start due to idiotic move on my part! Stood up with PTO on!!! #10
Not to totally hijack this, but NEVER get off the tractor with the brush hog running! I'm the farthest thing from the safety police, but this is just a wicked bad idea. Anybody read "Lancaster Farming"? Recall the article on last weeks front page? It was pretty ugly.
   / Help - won't start due to idiotic move on my part! Stood up with PTO on!!! #11
While I agree you shouldn't get off while brush-hogging, I have done so... In every instance I have done so, I have been on flat ground with no risk of rollaway, and what I was getting down for was to go to the front of the tractor and remove some limbs or something that I didn't want to risk my tires on. I would never walk around to the rear while it's running. Either way, no matter what the reason, good idea or not, the simple act of raising your butt from the seat shouldn't risk breaking something. An operator presence switch on anything large enough to have a traditional PTO is sorta silly considering there are several PTO implements that don't need an operator in the seat.
TRUST ME - I never had before and know better! Not too prideful to just admit that I just wasn't thinking! errrgh
I have checked the battery (full charge) and even jumped off using my F350. After messing with this and posting questions all over, I still can't figure it out but I am convinced it is the PTO that is still engaged. I disconnected the bush hog and can only turn the PTO about a half turn. Also, I have no hydraulics so whatever it is has shut the entire tractor down including the electronics. I jiggled the PTO handle, followed the cable to the transmission and tried to reset there - nothing. Very frustrating on a dumb move. This tractor has been absolutely awesome - perfect running. So, by me getting up off the seat with PTO engaged has triggered something.
   / Help - won't start due to idiotic move on my part! Stood up with PTO on!!! #14
I feel for you. This a tough one. Can you move the tractor at all- tow or push?
   / Help - won't start due to idiotic move on my part! Stood up with PTO on!!! #15
I once was mowing and all was fine. I shut down for lunch. After lunch, my Mahindra would not start. crawled underneath and found a stick had pulled the wires off of the neutral saftey switch.
hugs, Brandi
   / Help - won't start due to idiotic move on my part! Stood up with PTO on!!! #16
This is the reason why I defeated the seat switch.
   / Help - won't start due to idiotic move on my part! Stood up with PTO on!!! #17
So is the seat switch also the neutral saftey switch? I can move my steering wheel up and forward and stand up while mowing. Do you have a wiring diagram to trace out the circuit from the PTO to see what all systems that circuit accesses?
hugs, Brandi
   / Help - won't start due to idiotic move on my part! Stood up with PTO on!!! #18
Keep checking, fuses okay. Have you tried using a jumper at the starter to see if the engine will turn over or start. Is the instrument panel illuminated? Do the lights work? If all else fails, call the expensive Service Truck and then kick yourself for not finding the simply problem. Don't ask how I know that way to repair something.
I have defeated the seat switch - disconnected it and then took the fuse out as well. Neither worked. YES, the tractor will roll but no hyrdraulics and all power is off (power steering, etc.). Again, I think it is a safety pin that is blocking the electronics all together. I just have no idea how to reset the safety pin/button/trigger etc.???? This has been the most frustrating thing ever! errrgh (again) Any input is appreciated.
   / Help - won't start due to idiotic move on my part! Stood up with PTO on!!! #20
Does the dash turn on when you tun the key over? Not cranking could be related to something in the safety circuits (ie: neutral switch, PTO switch, etc) but if its acting like the battery isn't there (ie: no lights, nothing coming up on the dash), that is NOT the problem.
Aaron Z
2020 CATERPILLAR 299D3 XE SKID STEER (A60429)
2020 CATERPILLAR...
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
2014 Ford Flex SUV (A59231)
2014 Ford Flex SUV...
iDrive TDS-2010H...
Unused 2025 CFG Industrial MH12R Mini Excavator (A59228)
Unused 2025 CFG...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
