Help - won't start due to idiotic move on my part! Stood up with PTO on!!!
   / Help - won't start due to idiotic move on my part! Stood up with PTO on!!! #11
While I agree you shouldn't get off while brush-hogging, I have done so... In every instance I have done so, I have been on flat ground with no risk of rollaway, and what I was getting down for was to go to the front of the tractor and remove some limbs or something that I didn't want to risk my tires on. I would never walk around to the rear while it's running. Either way, no matter what the reason, good idea or not, the simple act of raising your butt from the seat shouldn't risk breaking something. An operator presence switch on anything large enough to have a traditional PTO is sorta silly considering there are several PTO implements that don't need an operator in the seat.
TRUST ME - I never had before and know better! Not too prideful to just admit that I just wasn't thinking! errrgh
I have checked the battery (full charge) and even jumped off using my F350. After messing with this and posting questions all over, I still can't figure it out but I am convinced it is the PTO that is still engaged. I disconnected the bush hog and can only turn the PTO about a half turn. Also, I have no hydraulics so whatever it is has shut the entire tractor down including the electronics. I jiggled the PTO handle, followed the cable to the transmission and tried to reset there - nothing. Very frustrating on a dumb move. This tractor has been absolutely awesome - perfect running. So, by me getting up off the seat with PTO engaged has triggered something.
   / Help - won't start due to idiotic move on my part! Stood up with PTO on!!! #14
I feel for you. This a tough one. Can you move the tractor at all- tow or push?
   / Help - won't start due to idiotic move on my part! Stood up with PTO on!!! #15
I have a 2010 MX5100 Kubota. Like an idiot, I got up with the PTO engaged this past (w/6' JD Bush Hog attached) Saturday and the tractor shut down. Turned PTO off and tried to restart and it seems the entire electrical system is half on. A faint buzzing sound is coming from below dash when I turn the key on. When I turn the key once more to start, all lights go out - nothing. Battery is good, wiring is good, checked all fuses (all good), checked safety switch on seat (seems to be good and correctly working). Acts like there needs to be a breaker reset - or something related but I have no idea. Even with the tractor on, the flashers barely turn on. What is even stranger - I can leave it on with the faint buzzing for 30 seconds, turn it off and then turn it back on, all the regular check lights turn on but when I go and turn the ignition once more...nothing and it goes back to the fainting buzz sound. Can't find anything in the manual. Sitting in the middle of my pasture dead. HELP! Thanks, Scott
I once was mowing and all was fine. I shut down for lunch. After lunch, my Mahindra would not start. crawled underneath and found a stick had pulled the wires off of the neutral saftey switch.
hugs, Brandi
   / Help - won't start due to idiotic move on my part! Stood up with PTO on!!! #16
This is the reason why I defeated the seat switch.
   / Help - won't start due to idiotic move on my part! Stood up with PTO on!!! #17
So is the seat switch also the neutral saftey switch? I can move my steering wheel up and forward and stand up while mowing. Do you have a wiring diagram to trace out the circuit from the PTO to see what all systems that circuit accesses?
hugs, Brandi
   / Help - won't start due to idiotic move on my part! Stood up with PTO on!!! #18
Keep checking, fuses okay. Have you tried using a jumper at the starter to see if the engine will turn over or start. Is the instrument panel illuminated? Do the lights work? If all else fails, call the expensive Service Truck and then kick yourself for not finding the simply problem. Don't ask how I know that way to repair something.
I have defeated the seat switch - disconnected it and then took the fuse out as well. Neither worked. YES, the tractor will roll but no hyrdraulics and all power is off (power steering, etc.). Again, I think it is a safety pin that is blocking the electronics all together. I just have no idea how to reset the safety pin/button/trigger etc.???? This has been the most frustrating thing ever! errrgh (again) Any input is appreciated.
   / Help - won't start due to idiotic move on my part! Stood up with PTO on!!! #20
Does the dash turn on when you tun the key over? Not cranking could be related to something in the safety circuits (ie: neutral switch, PTO switch, etc) but if its acting like the battery isn't there (ie: no lights, nothing coming up on the dash), that is NOT the problem.
Aaron Z
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
2017 Case CX145D (A60462)
2017 Case CX145D...
1660 (A59213)
1660 (A59213)
