nc redneck
- Joined
- Dec 19, 2012
- Messages
- 566
- Location
- Apex nc
- Tractor
- Kioti Dk45SE Sold Kubota BX 2200 Sold Kubota B 3200 Loader WR Long 4 in 1
First class work. Whatever you charged was probably not enough.
What kind of trailer is the frame from? I would compare the size of the beams to commercial equipment trailers. If it was a mobile home it may require more strength. I have seen triangulation bracing added to frames to make them stronger.I came a cross a deal on a trailer frame and decided to convert into a 5th wheel trailer to haul my equipment. It has a 29' deck and I want to shorten it up to 26' I was originally going to cut it off the front but all my buddies are telling me to cut it off the rear. My question is how far back should the axles be from the tongue of the 5th wheel or front of deck? I know most of my regular trailers the axles are 1' back from center ( if trailer is 20' long axles are 11' back from front of trailer) With a 5th wheel can I get away with the axles being a little further back?
I've built a couple gooseneck adapters for flatbed trailers in the past. One for me, other for a buddy. They are a lot easier than one would think.![]()
My buddy removes his adapter all the time using his FEL on his tractor. I haven't removed mine yet.That's an interesting way to convert it, I'd never have thought of that and just cut the whole tongue off. Why did you do it that way and is designed to un-bolt to return to a bumper pull?
Yep, I have that problem too, that's why I have a projects file where I save pictures like Shield Arc's gooseneck adapters.That sir... is brilliant!
Very nice work too btw.
This idea will go into the memory bank.
My problem is... I'm at the age where something has to come out to put something in.
Hope whatever comes out isn't something I need next week!
