FEL Mounted Plow or Back Blade
   / FEL Mounted Plow or Back Blade #11
I converted a truck plow too. Here's a video of it. My plow retains its original 12V hydraulic pump and electrical controls so I can swap it back over to the truck if need be. I won't be without the front plow (my preference) but this winter I'll be trying out a rear mounted grader blade too for fun. I found a box blade was useful for pulling snow in at the end of the driveway so I didn't need to back the tractor out into traffic on a hill where the road also curves. The only downside of the box blade was it clogged up easily, I figure the rear blade will be more useful since it deflects snow and I might be able to cut wider paths if I have both blades angled to opposites sides. Here's a good video from EA on rear blade snow removal.
Anywho, funny story re snow piles. I went to Texas last winter for Christmas and left my wife the keys to the GMC with the same Boss plow on the tractor. There was a few big storms in Maine that week and my wife plowed out towards the end of the driveway but didn't push the piles far enough to either side to get a vehicle through. Not knowing what to do then, she got out the snow shovel and dug a path between the two piles just large enough to get her mini cooper out the driveway to pick me up at the airport, LOL! Yup, I had to use the tractor loader that evening to move both piles of snow at the end of the driveway before it froze solid!
Anywho, its no big deal if you have quick attack to swap the plow over to the loader bucket. I went back forth pushing snow and moving firewood all winter. Just keep an eye on the weather forcast and make sure the correct attachment is on before the snow flys.
   / FEL Mounted Plow or Back Blade #12
A plow setup like vtsnowedin's works the best. It keeps the weight of the loader on the tractor. With the weight of the loader on the tractor 4WD is more effective and there is not as much weight riding of the skid shoes so it will not dig in the gravel as bad.
This is my plow. I want to get rid of it and convert a truck plow and do a similar setup like vtsnowedin's.
   / FEL Mounted Plow or Back Blade #13
I use a back blade. It's great for less than 10", more and it gets slow or i go in reverse. A fel plow would be way better but much more costly.
   / FEL Mounted Plow or Back Blade #14
What brand is your plow?
Have you used it with chains on the fronts?
Whatdaya want for it?;)
   / FEL Mounted Plow or Back Blade #17
It is a Edge Plow by CE Attachments. I think they are hooked up with Gehl that makes skid steers.
You can put bolts in it to lock out the spring trip and use it as a dozer blade but I never used it like that.
Product Navigation
I never used it with chains on the front or rear.
Let me think about a price. Do you live close to Virginia?
   / FEL Mounted Plow or Back Blade #18
How about $3200. It has flat faced couplers on it. If your tractor has AG couplers I have a new set that I will switch out.
Thankyou Roger, I am in WA state, that is one stout blade, I'm thinking that trying to figure out a way to ship it, and cost of shipping would put it out of my budget.
When I seen how much it weighed, I knew it wasn't a cheap plow, that thing is a beast.
With it being so heavy, I wonder if you took the skid shoes off, and just tried to eyeball the blade height without running the loader in float how things might work? 1300 pounds setting on the ground plus the loader arms is gonna dig stuff up.
I wonder if the first the first time you get 2 or three inches of snow, if you drive around drive around and pack it down to get a base, then maybe that might keep things out of the gravel better?
   / FEL Mounted Plow or Back Blade #20
Yeah it would cost a fair amount to ship it since it is so big. This blade weighs 750lbs, it is the "light duty" one. The ground here is so uneven that you would have to constantly be working the loader up and down or the plow would hit and you would be really digging in. I can manually work it up and down on the more level areas and do fine but I can't go but 3 or 4 MPH doing this. I am worried that packing it will turn it into ice.
2016 Nissan Versa Sedan (A55853)
2016 Nissan Versa...
2020 VOLVO VN SERIES SLEEPER (A55745)
2020 VOLVO VN...
2015 Ford F750 Reel Loader Truck (A52377)
2015 Ford F750...
New/Unused Gold Mountain Container Shelter 30ft x 65ft x15ft (A54865)
New/Unused Gold...
2014 Ford F-450 Dump Truck, VIN # 1FDTF4GT9EEA61310 (A54865)
2014 Ford F-450...
2017 Caterpillar D5 K2 LGP (A55302)
2017 Caterpillar...
