2010 DK40 SE Won't Start
   / 2010 DK40 SE Won't Start #1
TimbourLarry
Member
Madison ms
Mahindra 3510, 2010 Kioti DK 40 SE
I have appreciated reading many of the prior posts and I hope you will indulge me as this will be my first post and I have limited experience performing mechanical/electrical work on tractors. In February I bought a used Kioti DK 40 SE which had been traded at a New Holland dealership with only 75 hours and it currently has 95 hours. I love the tractor but about a month ago I began to experience intermittent starting difficulties and then ultimately it failed to start at all. Thinking to the problem to be in the fuel system, I replaced the fuel filter and bled the fuel system including the injectors but had no success in starting the tractor. After reading some of the posts I decided to remove the stop solenoid and the tractor immediately started. Thinking I had a bad solenoid I replaced it only to learn that the tractor would still not start. The closest Kioti dealership is over 100 miles away and I had a discussion with the service manager who indicated that the problem could be a faulty ignition switch as Kioti has experienced problems in that area. I believe the tractor is still under warranty but can't get the courtesy of a reply to my email from the Kioti US headquarters in NC. The knowledge base on this board is amazing and I would appreciate any advice someone could give as to what my next steps should be.
   / 2010 DK40 SE Won't Start #2
Kioti does have a 4 year power train warranty. Don't think it will include a switch thou. If it was mine knowing what I know about their switches I would replace it. But first take a jumper cable and connect from Neg battery post to a good ground to kill a possible bad cable problem
   / 2010 DK40 SE Won't Start #3
I don't know about that Murph, they replaced mine no charge the last time I had it serviced last month. Don't think it was just a courtesy as the dealer I'm going to now is not the one I purchased the Tractor from..
   / 2010 DK40 SE Won't Start #4
OK.. this gets fairly complicated pretty fast..Do you have a good multimeter and know how to use it? Also further information HST or gear, and ROPS or Cab model? Do you have a pretty good understanding of what relay coils, and contacts and solenoids do? The reason I ask this is because you stated you have a limited experience in electrical.. It seems you have more experience in mechanical to know enough to suspect the fuel stop solenoid.. Of course you wasted some bucks already in what I call the "shotgun" parts changeout approach, instead of using the scientific method approach to electrical troubleshooting.. There is no shame in this, as many mechanics use this approach also, but it is costly when you do it and you don't work for a repair shop with a shelf full of spare parts to "shotgun" in and out when that did not fix it either.
If you will keep up the dialog and answer the questions and keep me informed of your every move, I will try to help you troubleshoot. Keep in mind this is a very difficult thing to do, to assist someone over a forum like this, but we have had some success at it. It just depends on how good you are at informing me of what you see, and how good I am at interpreting the results. The next move is up to you.
James K0UA
   / 2010 DK40 SE Won't Start #5
Then go with it. I take power train to be engine trans or rear diff but who am I to say.
   / 2010 DK40 SE Won't Start #6
Murph I believe him to say that the tractor cranks fine, but will not start. And it will not start because the fuel solenoid has not been operated. He knows this because when he removed the fuel solenoid entirely the tractor cranked and started. Of course he replace the fuel solenoid thinking it was defective, and of course that did not fix the problem as the original fuel solenoid is not defective, nor is the replacement one. To the original poster please correct anything I said here that is not true.
James K0UA
   / 2010 DK40 SE Won't Start #7
James K0UA
James, You do this better than me so I'll watch.
   / 2010 DK40 SE Won't Start #8
It ain't easy for any of us.. I could fix it a heck of a lot faster If I was standing beside the tractor with a printed out schematic in one hand and a good multimeter in the other. This remote control trouble shooting is for the birds!:duh:
   / 2010 DK40 SE Won't Start #9
He is already halfway to a solution as the problem is now "why does not the fuel solenoid operate" instead of "why does not the tractor start" and we have determined the tractor cranks, but does not start, and we know why.
   / 2010 DK40 SE Won't Start #10
The first thing we are going to do is determine which model of engine stop solenoid you have. The prior to may 2007 with only 2 electical connector terminals or the post may 2007 with the 3 electrical connector terminals. I am going to stop here for now until I hear from the original poster.
James K0UA
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
(10) 2 PLUG VALVES (A52472)
(10) 2 PLUG VALVES...
2121 (A51244)
2121 (A51244)
43030 (A51691)
43030 (A51691)
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
1267 (A50490)
1267 (A50490)
