Ford 3000 driving me insane!
   / Ford 3000 driving me insane!
pressure is a combination of flow and resistance.. with an injector line cracked open.. you will have very little flow and no resistance.. thus no appreciable pressure.
Makes sense. Thank you.
   / Ford 3000 driving me insane! #12
two other things you can check is your fuel valve in the tank of the tractor is has a filter on it or should I have seen them stop up after running a little then as soon as it dies the clock lets loose because there's no vacuum on it also in the back of the injection pump when the input line screws on there is a filter and a metering valve that could have trash in it
Thank you! I'll check that as well.
   / Ford 3000 driving me insane! #14
Had to laugh out loud, sounds like my luck!
I had my 3000 stuck on a stump while bush hogging , another time sunk to the frame , all while running out of gas and no hydraulics!!!
I think the longest I've had it running continuously without something breaking is about 3 hours!
I got it running although I haven't fixed the leaky radiator yet. Replaced the fuel shutoff which came with a new filter attached. Replaced the fuel filters with spin on adapters and cleaned out the lines and filter plate. After priming it started right up and ran fine.
New filters with adapters.
   / Ford 3000 driving me insane! #17
Wow, look at all that room! Looks nice and easy to make a filter change on.
Less messy and easier to prime as well because you can fill the filters with clean diesel before you spin them on.
   / Ford 3000 driving me insane! #19
SoGeorgia,
I'm sorry or your trouble but, happy for the information that Soundguy is sharing. It might help me in the future.
JOHN DEERE 5083EN LOT NUMBER 122 (A53084)
JOHN DEERE 5083EN...
1838 (A51248)
1838 (A51248)
KUBOTA SVL97-2 SKID STEER (A51246)
KUBOTA SVL97-2...
2001 Dodge Ram Wagon 3500 Passenger Van (A51692)
2001 Dodge Ram...
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
