miller 252 for 700$ ?!? What do I need to check before I buy??
   / miller 252 for 700$ ?!? What do I need to check before I buy?? #11
There were some 252's that had electronics problems. Plastic bracket for the feed roller drive? A 25' gun would be a special order. Just go with a 15' gun. Bernard is a good gun. Hopefully the machine is still good internally although it sounds like it has been abused some. I wouldn't believe the only 100 hours story for a second.:confused2: $650 is still a good price as long as it doesn't need anything major replaced.
   / miller 252 for 700$ ?!? What do I need to check before I buy?? #12
I got a new 252 at work last year and soon as I turned it on I got a loud hum and poof dead after that. Blew a board first time the switch was turned on. So yes I was one of the lucky ones that got one with electrical problems. And honestly I think the machine runs like junk. Unless I just got a dud. I personally own a older tapped millermatic 185 and a newer 211 they will run circles around that 252. Like said tho, I think we just got a dud. I do here great things about it.
   / miller 252 for 700$ ?!? What do I need to check before I buy?? #13
The price was good, fix your drive roll, get a new 15' gun and a good cleaning and you should be good to go. I have a new 252 I got in June, list was 2300.00 I went out the door at 1950.00 at Air Gas. So you still did good. I also have MM211 and I am on the same page with weldermike, the 211 welds much better than my 252.......not sure Y but it does..
   / miller 252 for 700$ ?!? What do I need to check before I buy?? #15
Have used both...own a new 252.
Gotta say there is no comparison in weld quality and appearance. 252 hands down. Now on thin stuff the MM211 may take it;don't know haven't tried .023 with 252 yet.
Well after I somehow accidently deleted my intended response instead of posting it, here is the short version. repair center only found a messed up spring besides the known gun/ drive motor bracket/mount issue. they will due a 'full load test' after the above is replaced. current estimate right around 300$, so I don't feel too bad. I would like to thank everyone again, and do have a question regarding welding wire thickness. most of my welding should be 1/8 to 1/4, but I have a project planned with up to about 10 ft of bead (total...not one single bead) on 1/2 steel plate. I know .045 would be best for really thick stuff, but is it worth buying new drive rolls and liner for 80-100$ for that project, manual said .035 is ok, just with a higher feed speed.
   / miller 252 for 700$ ?!? What do I need to check before I buy?? #18
Pretty sure the liner in the new gun is .035/.045. If you need to use .045 you can buy a 2# or 10# spool. Also check your drive roll it may be 35 on one side and 45 on the other.
the drive rollers are .030 and .035, I wish it were .035&.045. as for the gun/ liners, it is my understanding from the owners manual and replacement miller parts that the liners are 030/035 and that the 045 is its owner liner, but I am not an expert, so there is a good chance I am misunderstanding something.
but it appears I can weld some down to 1/8" with 045 so I that case I should be ok just sticking with .045.
Toro 3100D (A50324)
Toro 3100D (A50324)
2014 FORD F-350 SUPER DUTY CREW CAB FLATBED TRUCK (A51243)
2014 FORD F-350...
SET OF (2) DELTA DUMP TRAILER SWINGING DOORS (A51244)
SET OF (2) DELTA...
2016 CHEETAH 40FT CHASSIS TRAILER (A52141)
2016 CHEETAH 40FT...
2011 Hyundai Sonata Sedan (A50324)
2011 Hyundai...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
