'69 Ford 3000 Water Pump
   / '69 Ford 3000 Water Pump #1
SoGeorgia
South Georgia
Ford 600, Ford 3000, Allis Chalmers B
Good afternoon. Anyone have any tips or tricks to make a water pump replacement go any faster/smoother on a '69 Ford 3000?
Thanks in advance.
   / '69 Ford 3000 Water Pump #2
? have someone do it for you?
the tinwork will be MOST of the work. the water pump itself is straightforward...
I reccomend repalcing hoses and coolant at this time unless they are new.. as well as thermostat. good time to clean out radiator core as well as backflush the block.
use a good fleet / sca/dca coolant if it's a diesel... don't hurt even if it doesn't specifically need it.
great time to tap on some freeze plugs too and see if any of them are paper thin.. i have seen PAINT holding some together.. would hate to waste coolan cuz a rotten plug let go.. etc..
repalce the fan belt unless good / new as well.
Thanks brother.. I appreciate it.
   / '69 Ford 3000 Water Pump #4
I finally got my hydraulics straightened out, bus hogged for about 3 hours and my water pump went out!
Not to hijack, but can you replace the water pump without taking the radiator off?
You have to remove the radiator. The good news is I had the hood, front end, radiator and water pump off in an hour.
That being said, now I have other unrelated issues to post on when I get a chance this morning.
   / '69 Ford 3000 Water Pump #6
I have the hood off, one radiator bolt out, and the other is just spinning? Anybody have any ideas on how to get this Bolt off, I think it is an aft market carriage head, that's spinning?
Does the hood need to come off to remove the radiator?
I took my hood off. I don't think I could have gotten to everything with it on.
Are you talking about the bolt at the bottom of the radiator that goes straight down? I didn't look that close but I don't think you can get to the head of it.
My new water pump works great! It pumps ALL the water out of the hole in the radiator I found when I got stuck on the stump!
Oh, I also have a fuel problem now. It won't start. I have a new fuel shutoff and spin on fuel filter adapters coming. I guess then I'll find out the fuel pump is bad as well.
   / '69 Ford 3000 Water Pump #8
if you can hold the head wit a small prybar and get it.. it might work.. otherwise neuter it.
   / '69 Ford 3000 Water Pump #9
I just changed the water pump in my tractor. From what I've gathered it's a 3500 industrial. I don't know how much different it is from a 3000, but I didn't need to pull the radiator out to change it. Pulled the front support from the block to the nose, air intake hose, left the fan sitting in the shroud, a little wiggling and it came right out. Have any pictures?
I'm not saying it's not possible but it looked too tight in there for me to attempt it.. In the end it only took me an hour to get the hood, front end, radiator and water pump off.
2019 Kenworth T270 Rollback Wrecker (A53117)
2019 Kenworth T270...
City of Lakeland (A51691)
City of Lakeland...
2011 NISSAN FRONTIER EXTENDED CAB TRUCK (A51247)
2011 NISSAN...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
2016 Ford Focus SE Sedan (A51694)
2016 Ford Focus SE...
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51692)
2018 Chevrolet...
