3-Point Hitch twisting drawbar on 3 point hitch
   / twisting drawbar on 3 point hitch #1
mregis
Tennessee
JD 4210
When I try to move my small trailer around the yard,using the ball attached to the drawbar, it has the tendency to twist/roll around. How can this be preventend?
I have not figured how to send a photo!..Thenks
   / twisting drawbar on 3 point hitch #2
That is a common problem - the drawbar just doesn't work for that application.
Fixes:
>There is a kit that attaches to the end of the bar and to the lift arm. The kit holds the bar in place.
>There are methods to attach the drawbar to the top link by a vertical shaft.
Do a search and you'll find lots of information. (First look at "Similar Threads" at the bottom of this page.)
   / twisting drawbar on 3 point hitch #3
Drawbar lock:
Top Links, Draw Bars, Draw Bar Locks, Lift Arms, Draw Bar Kits, Stabilizer Kits, Swinging Draw Bar Kits, Stabilizer Bars - SSB Tractor
Bruce
   / twisting drawbar on 3 point hitch #5
I tried one of the store bought locks as pictured in post #3, but took it back because I couldn't get it to work right. YMMV!
Here is a picture of what I made for my Ford 8N. Cost to make was about $5. I no longer use it because I bought a KK trailer mover to use instead.
   / twisting drawbar on 3 point hitch #6
You are also going to need stay strap or the chain the draw bar to keep it from going up.
That is similar to how mine was made except mine bolted to the lift arm.
   / twisting drawbar on 3 point hitch #7
What Roger said! ↑↑
I only use a chain or stay strap on my small trailer if I take it off level surfaces. I always use one or the other devices on my larger trailer. Using a safety device (all of the time) is probably a better practice to get into.
Oh, I almost forgot.... :welcome: to the forum mregis!
   / twisting drawbar on 3 point hitch #8
I bought something very similar to this from a company that used to advertise on TBN:
Ballard Fabrication
Works great and build very well.
   / twisting drawbar on 3 point hitch #9
Here is what I made to use on my Kuboa B7100 & Ford 8N. Works great as a trailer hitch, log skidder, & I have made gardening implements that use the same hook-up.004.JPG
2016 Toro Workman HDX-D Diesel Utility Cart (A59228)
2016 Toro Workman...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
2002 Ford E-450 Enclosed Service Van (A59230)
2002 Ford E-450...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
207269 (A52708)
207269 (A52708)
