Stimw
Elite Member
It was the 10.00 x 20 Dayton rims that came on the F700 of our that we replaced with the one piece radial tire Dayton rims pulled from wrecked school buses. Locally they charge more for mounting the bias tires on the split rim Dayton wheels. Many still run them on older equipment. China imports the tires to fit this old Dayton rim. Dayton rims can be changed by hand if needed because with the nuts near the tire vs near the axle not as much torque is required to attach/remove them. To mount new tires on the Dayton radial tire rims you will want tire mounting equipment. They have a valley in the rim for the bead to drop into when mounting the tires to the rims. The split ring bias tire rims are not v shape.
The one piece rims have 22.5 tubeless or the larger are 24.5 tires that won't fit the older rims.
They do mount up without problems with lub and a tire hammer. The hard part is getting the bead to seal. They use those Cheetah Air Tanks that give a heavy blast of air to pop them up on the rim. Or some gas and a match!!!
A lot of people got hurt when Ford came out with a 16.5 rim for 1 tons and they got put on a 16" rim. When they aired them up they would blow off the rim!!
