pclausen
Veteran Member
I removed the aluminum spacers and the wheels cleared the drums fine. I was basically able to shed the following unsprung weight, and I'm sure the truck will handle much better once I get it on the road again.
Shot directly at the rim. I did reuse the plate. The new wheels have an ever so slightly larger hub hole diameter compared to the old split rims (4.60" instead of 4.50" or something like that). I don't know if that is going to be an issue or not... I can see fabricating a sleeve to slide over the hub to take out this slop if needed.
Inside shot showing the air space everywhere between the wheel and drum. Not sure why aluminum spacers were used before...
On the left rear, I pulled the axle shaft out:
I see that there is a key (yellow arrow), that needs to be removed next. It is stuck in there real good. I think I need to loose that large retaining nut just a hair in order to remove the key, and then remove that nut all the way.
It looks like I'll need some sort of special nut remover to get that nut off?
Btw, that was some nasty looking oil that came out, so I'll be changing the rear diff oil for sure!
