Stimw
Elite Member
The part you are calling a caliper is actually a wheel cylinder.
They will get stuck from sitting. Usually the dust cover doesn't seal and there is an aluminum piece up against the cup. The aluminum piece will corrode to the steel cylinder.
I have taken them apart and cleaned them up and they worked again. As long as the cylinder isn't pitted.
NAPA used to be able to match up the wheel cylinders just by the 3 digit casting number.
Check out your brake lines really well!!! I worked on a low 60's 1 ton that someone repaired the rear brake line with low pressure fittings with ferals. (brake line pressures can be about 2000 psi)
Brake lines must be flared and preferably double flared.
In case you didn't know, when putting the rear hubs back on put grease on the bearings which will protect them until the rearend oil reaches them.
