3pt implement for grading split driveway? (grass strip in center)
   / 3pt implement for grading split driveway? (grass strip in center) #1
JLinder
Astoria, OR
Kioti DK5510HS
My gravel driveway has a grass strip in the center which makes it a little more challenging to maintain. Is there an implement out there, or one that can be modified so I can grade both sides in one pass?
Here's a pic:
   / 3pt implement for grading split driveway? (grass strip in center) #2
Get a wide (8') rake and remove the center tines?
   / 3pt implement for grading split driveway? (grass strip in center) #4
Looks like it only needs some occasional mowing to me!! :thumbsup:
   / 3pt implement for grading split driveway? (grass strip in center) #5
Looks like my driveway. I blade mine out in the spring using a grader blade to first remove the slush, then reverse the angle once the slush is all gone and throw the gravel back out of the yard and into the drive. I then use the box blade to spread, fill, smooth and otherwise recondition the drive. The grass all grows back in the middle in a few short weeks.
Joe
2016 SDLG L948F WHEEL LOADER (A51242)
2016 SDLG L948F...
Toro Zero Turn Mower (A50324)
Toro Zero Turn...
2013 Honda Odyssey EX-L Mini Van (A50860)
2013 Honda Odyssey...
2005 Kia Optima Sedan (A50860)
2005 Kia Optima...
UNUSED Four-Layer Black Metal Storage Shelf (A50860)
UNUSED Four-Layer...
International 574D Tractor (A50860)
International 574D...
