3pt implement for grading split driveway? (grass strip in center)
   / 3pt implement for grading split driveway? (grass strip in center) #1
JLinder
Astoria, OR
Kioti DK5510HS
My gravel driveway has a grass strip in the center which makes it a little more challenging to maintain. Is there an implement out there, or one that can be modified so I can grade both sides in one pass?
Here's a pic:
   / 3pt implement for grading split driveway? (grass strip in center) #2
Get a wide (8') rake and remove the center tines?
   / 3pt implement for grading split driveway? (grass strip in center) #4
Looks like it only needs some occasional mowing to me!! :thumbsup:
   / 3pt implement for grading split driveway? (grass strip in center) #5
Looks like my driveway. I blade mine out in the spring using a grader blade to first remove the slush, then reverse the angle once the slush is all gone and throw the gravel back out of the yard and into the drive. I then use the box blade to spread, fill, smooth and otherwise recondition the drive. The grass all grows back in the middle in a few short weeks.
Joe
2017 JLG G5-18A Telehandler (A50490)
2017 JLG G5-18A...
Birmingham Wood Stove (A48837)
Birmingham Wood...
2005 Great Dane Trailer, VIN # 1GRAA96265S700587 (A48836)
2005 Great Dane...
2022 CATERPILLAR 289D3 SKID STEER (A50458)
2022 CATERPILLAR...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2012 Ford F-350 Service Truck (A48081)
2012 Ford F-350...
