Will this backhoe fit my Kubota b2410 ?
   / Will this backhoe fit my Kubota b2410 ? #1
JP9MM
Member
NY, LI
B2410 , AC712
Kelley B10 , approx 600lbs
pto driven.
Can i just hook it up to the 3-pt hitch ? or what else would i need ?
I'm going to call the company, anyone have ideas on how to look one of these over before buying ?
Seller says its been sitting 7 years but used very little. He doesn't have a machine to demo it either so i'm not sure what i might be walking into
   / Will this backhoe fit my Kubota b2410 ? #3
Looks like it probably would, it's a very small unit. It will mount to the 3 point, but like *all* 3 point backhoes, a custom subframe is the best route. How much is the hoe?
It's a very basic unit, small and inexpensive. The valve is probably quite rudimentary. I would bring my tractor over and test before buying, if not crack some hoses loose and manually extend/retract all cylinders, make sure they appear to seal okay. Check for pitting on the chrome shafts. Check all hoses. Check for leaks. Cracks/welds/etc.
Thanks, manually extending/retracting cylinders is not something im familiar with doing.
Hes asking 2k for it
3038 (A49339)
3038 (A49339)
2003 Mack MR688S 58 Meter Putzmeister Concrete Pump Truck (A45336)
2003 Mack MR688S...
AGT Industrial QK16R Mini Excavator (A43476)
AGT Industrial...
KC 28in.x90in. Metal V Bottom Feed Bunk (A49339)
KC 28in.x90in...
Kubota 48in Bucket (A46683)
Kubota 48in Bucket...
Skid Steer Hydraulic Hammer SSHH680 (A43476)
Skid Steer...
