JD X595 won't start
   / JD X595 won't start #1
TBS4664
Woodstock VT
JD X595
I was mowing and everything was running fine - stopped the 595 and turned her off - went to start her up again - heard a little "sparking" sound - the dash panel lights flickered for a min' - then nothing... no dash lights - no start - nothing... pulled the battery and made sure it was charged up - checked the 3 fuzes - just put the battery back in - turned the key - one dash light lit for split second... nothing after that... anyone got a suggestion?....... thanks - Todd
   / JD X595 won't start #2
TBS, welcome to the forum. Your JD is newer than mine but I'd look for a fusible link and/or a wire that is shorting out on a piece of metal. If you can put a multimeter on the back of your dash gauges, and then work your way back, that's where I'd start. Has to be a fuse of some kind, can you better describe the "sparking sounds" and did you also get a burning smell with it?
Hi - Thanks for responding... the spark sound was just one very quick one and there was a slight electrical short smell... oddly the fuses didn't seem to be blown - but I replaced them anyway... I'm wondering if it could be a ignition switch issue - ???.....
Lone Star dump trailer (A55973)
Lone Star dump...
72" ROCK BUCKET (A52706)
72" ROCK BUCKET...
401 (A52706)
401 (A52706)
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
2016 Ford F-150 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
