BX25D Breaking 3pt Sway Links
   / BX25D Breaking 3pt Sway Links #1
Jmtodd
Houston, TX
None
Twice now I have broken different welds on the 3pt Sway Links (the welds from the loops to the nuts).. In examining the rest of the welds, they are all pretty poor... Anyone know of an upgrade for these tiny little links? The first time one broke I was making a really gradual turn with a 4ft Brush Hog.. The second one broke when I was doing a bit of grading with a 4ft blade (one notch off of square creating the side force)... It seems these links in stock for just can tolerate much side loading at all..
   / BX25D Breaking 3pt Sway Links #2
Don't know if they're any stronger, but there's a TBN member here that sells telescopic stabilizers that replace the turnbuckles. Just can't remember what handle he goes by or where I saved the link to this site. Maybe someone else will post a link or his name.
   / BX25D Breaking 3pt Sway Links #3
I believe you are referring to Mark Hodge. The product he makes can be found here StabilWorks
Take Care,
Doug in SW IA
   / BX25D Breaking 3pt Sway Links #4
Definitely not right. Mine have been through a lot over 8 years and still as good as new. I suppose of you took a hard turn and snagged your cutter on a stump or something, there would be enough force to snap a link, but just ordinary use should not cause such a problem.
   / BX25D Breaking 3pt Sway Links #5
Are they maybe too loose, and the implement is slamming them back and forth until one breaks?
Bruce
   / BX25D Breaking 3pt Sway Links #6
   / BX25D Breaking 3pt Sway Links #7
I had mine on too tight once and snapped one of turnbuckles. Upon looking at it, the welds looks pretty cold to me as the molten weld is just a puddle on top of metal but holding the U part fine. I just grinded the old weld off and rewelded it back on with a hobart 125ez. no problems since. I didnt bother to reweld the other poor welds of turn buckles figures its just as easy to do it later when it breaks as I have access to my welding machine 24/7.
Thanks for all the responses guys.. I will definitely check out those telescoping links. I have a pile of welders, so welding these back is not an issue, and I agree that the welds were way to cold, not a good bond at all.. It is entirely possible I bumped a stump when turning with the shredder, but the blade was just a consistent, and relatively light side load.. I am definitely not leaving them too loose, I have a bit of a fetish about getting my implements set up properly..
   / BX25D Breaking 3pt Sway Links #10
Are you tightening them til they are snug or are you cranking them down real tight?
2019 Ford F-150 4X4 (A50397)
2019 Ford F-150...
2019 CATERPILLAR 440 BACKHOE (A51242)
2019 CATERPILLAR...
2007 FORD F-450 (A50854)
2007 FORD F-450...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
2012 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2012 STEPHENS...
Case Ih 2388 Combine (A50514)
Case Ih 2388...
