electrical connectors
   / electrical connectors #1
Smittyed
Foley
Kubota L3430
Does anyone know what type of electrical connectors or on Kubota L 3430, I cannot see paying a 1000 bucks for a complete harness when all I need is one 6 pin connector on the transmission, any help is appreciated.
   / electrical connectors #2
I'm going to suggest that you will get many valid responses if you post a photo of the connector. Many of us might be able to help that have no idea what your 6-pin connector looks like since we don't own Kubotas. A close-up focused picture from the side and looking into the connector would be ideal. Also, some measurements. Help us help you by giving a bit more info please.
I'll get a couple of pics when I get home this evening, and thanks for responding.
   / electrical connectors #4
Yes, a picture. But I've done a ton of electrical addons for my Goldwing and I don't necessarily feel constrained by the factory style connectors. Both Mouser Electronics - Electronic Components Distributor and Welcome to Waytek can fix you up with whatever you need in the electrical realm. Mouser lets you order more stuff in quantities of 1 or 2 whereas Waytek typically has minimums.
   / electrical connectors #5
ditto that.. i've used generic molex connectiors many times when doing repairs or upgrades. especially if a 6$ conenctor set saves a 1000$ harness
   / electrical connectors #6
Ditto what others said.
If you are lucky enough to find a 6 pin connector half that matches, odds are it is going to cost more than just getting a generic 6-pin SET
I dont have a problem rewiring the tractor, I have already made a couple of repairs, unfortunately the male plug for this is snap ringed into the transmission and the female (chewed part) is missing one of the female pins, I have already bought several plugs from the sources you guys mentioned, and none fit, very close but not it. Most of what I have found leads me to believe they are Toyota automotive connectors, I just need to find the right pin to replace the missing one.
I have included some pics. IMG_0947.jpgIMG_0948.jpgIMG_0950.jpgIMG_0951.jpgIMG_0952.jpgIMG_0953.jpgIMG_0954.jpgIMG_0955.jpgIMG_0956.jpg
The wing pic is for you Stick, I have installed many farkels to it as well, I don't mind changing things but this is a proprietary plug that is in the transmission, I don't have a choice.
   / electrical connectors #9
the pics are way to unclear to tell anything.. but if you thought it was a auto connectior.. i'd stroll thru a junkyard at lunch...
otherwise.. i'd figure out how to go pin to pin directly with a home made wire job not usinghte conenctor. or usingthe connector with 1 pin moded.
   / electrical connectors #10
I do not want to make a suggestion that will lead you down a black hole.
But WORST case senerio:
I do see a snap ring at the base of the connector on the tractor and a plate that can be removed on the side.
If you truley cannot get the replacement parts, there is a possible workaround.
Without knowing what is inside it is hard to guess further.
Can you ger a parts view of the innards?
2004 950M Towable Cement Mixer (A55851)
2004 950M Towable...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A55302)
John Deere 6105E...
1836 (A57192)
1836 (A57192)
UNUSED RAYTREE RMVR76 76" HYD VIBRATORY ROLLER (A57193)
UNUSED RAYTREE...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2016 Ford Taurus Sedan (A55853)
2016 Ford Taurus...
