Fluid Film
   / Fluid Film #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
My new 1025 and new Frontier bush hog has been very difficult to get the PTO shaft to slide onto the tractor shaft. Last time, I put the usual bit of white lithium grease onto the PTO shaft, but I also put a little bit of Fluid Film on the inner part of the PTO shaft that goes to the bush hog. It went right on! Wow!
Ralph
   / Fluid Film #2
Grease often prevents PTO shaft from coupling to the stub.
As you have discovered, Fluid Film is the right stuff. It is thick enough, but not too thick.
Scrub the splines with a brass or steel brush occasionally, wipe with a paper towel, then re-apply Fluid Film.
WD-40 works OK but Fluid Film is better.
   / Fluid Film #3
I put it on PTO shaft, all of the joints of the 3pt. the SSQA linkage, and anything else that does not have a grease zerk. The stuff is the closest thing to a Miracle in a can I have seen when it comes to lubricating/protecting things.
   / Fluid Film #4
Is it sold in stores?
   / Fluid Film #5
NAPA stores have spray Fluid Film at around $9. Stihl stores usually have it around $12.
To my surprise, my local rather small Tractor Supply does NOT carry Fluid Film.
   / Fluid Film #6
To my surprise, my local Tractor Supply does NOT carry Fluid Film.
Thanks Jeff.
   / Fluid Film #7
Ah HA! Thanks for posting this wee tip. And to k0ua for the further information.
I'll go and clean off the grease that I'd hoped (usually to no avail) would let the coupling for the tiller or the slasher slide right on without cursing for 15+ minutes! I've got a lanoline based spray to try out... Fluid Film isn't readily available in Tassie.
Ta & cheers!
   / Fluid Film #9
Ta & cheers!
Fluid Film is a Lanolin based product also. I like the Aerosol, as it is thin when it goes on and spreads by itself and then hardens up to about a soft grease like consistency.
James K0UA
   / Fluid Film #10
Fluid Film...I love fluid film!
I also use it on the PTO stub shaft as well as the drive shaft halves (as Ralph described). I use it both both the gear and range shift levers (where they enter the transmission case) too...and anyone with a Deere 4200,4300, 4400 and newer Deres with thos long levers...use Fluid Film to lubricate those levers!
Great stuff, Fluid Film!
2025 New/Unused Wolverine Ripper (A51573)
2025 New/Unused...
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
New/Unused CFG Industrial MH12RX Mini Excavator (A51573)
New/Unused CFG...
INOP/NON-RUNNING 2008 International 7300 Truck, VIN # 1HTWAAAN78J690166 (A51572)
INOP/NON-RUNNING...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A52577)
2016 WESTERN STAR...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
