Price on rear remotes
   / Price on rear remotes #11
Yep, that's the pricing you get from the "stealership". If you can't go that amount and have some time to buy components, and learn a bit about hydraulics. You can do it yourself and save quite a bit of cash. I guess it depends on what your needs are.
   / Price on rear remotes #12
my l5460 cost me around 2k for three OEM remotes installed. I asked the dealer if it were cheaper to do it upfront rather than later, and he said the price was the same.
When you see Kubota's prices on each part it's sort of criminal, but the OEM rears seem well designed if expensive. And they stack so you can put in two and then add another one fairly painlessly I think.
Now I don't feel the same way about the 3rd function valve, seems aftermarket gives more flexibility for configuration.
   / Price on rear remotes #13
The Kubota set up will look much cleaner then any aftermarket set up you could do. I would ask your dealer if they have a GL tractor with remotes so you can see how they are mounted.
   / Price on rear remotes #15
So I asked the dealer that I am buying my l5740 how much to add rear remotes and he quoted me $2000!!
Did not think it would cost that much. does that sound right or should/can I do it myself getting parts from another vendor??- Is is hard to install?- thanks as always
$2K--is that for a single, double or triple remote setup?
My Mahindra 5525 has dealer-installed triple hydraulic remotes--cost $700. Bought the remotes as part of the tractor package and is the dealer's own design.
This tells you right away--your dealer is marking up the cost of the parts and is really socking it to you for labor. The parts for my setup run about $600 (valves, hoses, quick disconnects).
Good luck
   / Price on rear remotes #16
I got three rear remotes with Top and Tilt on mine and recently configured an L6060 on the Kubota website and your dealer is about right and to me it was well worth it. Yes, you can do it, but for a cab tractor I believe Brian usually recommends OEM due to the clean installation and limited space.
As I mentioned in another thread, I have purchased hydraulic cylinders from Brian at Fit Rite for another tractor and they were really good quality, excellent customer service.
I really like mine, looks and works very nice; money was well spent. I have operated non OEM on open station tractors and prefer OEM setup.
   / Price on rear remotes #17
You can do this if you have any mechanical ability.
Not only will you learn, you will know how to take it all apart and fix if necessary.
Order this kit if you want 3 spools, two with float for T-N-T, and 1 spool for spring center action. 4 spools will cost a little more.
Order a 3000 psi hyd gage also.
No way is this going to cost over $800.
Be careful, they/someone will spend your money real quick
Y&catname=hydraulic]Surplus Center - 3 SPOOL 20 SERIES PRINCE STACK VALVE POWER BEYOND[/url]
$369.90
Add some hoses, fittings, a mount for the remote , and some QD's, and you are done, saving bunches of dollars.
   / Price on rear remotes #18
a single set of 2 remotes should just cost $750 installed.my 7040SU has 2 sets of remotes because thankfully the salesmen got confused an had the 2nd set installed at no cost to me.
   / Price on rear remotes #19
From Kubotas' website:
1 1ST POSITION LEVER & BASE KIT$587.00
1 2ND POSITION LEVER & STACKING KIT$316.00
1 3RD POSITION LEVER & STACKING KIT$316.00
1 DOUBLE ACTING VALVE$240.00
2 FLOAT DETENT VALVE$604.00
   / Price on rear remotes #20
I don't get it when some folks refer to a legitimate business thats buys the parts and resells them for profit then pays the people who do the work a "stealer". Please explain what there stealing.
2016 FREIGHTLINER CASCADIA (A53843)
2016 FREIGHTLINER...
2013 Ford Transit Connect Van (A52377)
2013 Ford Transit...
1994 INGERSOLL RAND SD100D PADFOOT ROLLER (A52706)
1994 INGERSOLL...
TEST YOUR BID BUTTON! (A52706)
TEST YOUR BID...
2020 Chevrolet Tahoe SUV (A52377)
2020 Chevrolet...
2013 CHEVROLET TAHOE (A53843)
2013 CHEVROLET...
